To minimize the spillage when removing the cooler... find two bolts to plug up the hoses with :D
Works a charm...
Remember, DO NOT EMPTY THE OIL INTO THE DRAIN! How would you like it if someone poured oil in your water bottle :P
So, how do you fill the oil up again? I take it there is a dipstick to check the level?
If you pull the top hose off and run the motor to empty the trans, wouldn't the cooler itself still be full of oil (and it would subsequently go everywhere)?
Sorry for all the questions.
Andrew
You fill the tranny through the dipstick tube.
I just pissed oil overwhere. Removed the hoe here and there and tried to get all i could. First i drained the sump though.
Also, i didnt jack my car up as i didnt want it on an angle to drain the oil.
I got a funnel and some hose, put them together, and stuck the hose in the dipstick tube. That is my dodgy assed method.
Alex, I've never totaly drained an auto with out taking converter out. Were u able 2 do that or r u only draining out what is pan and cooler lines. 2lt. doesn't sound much 4 an auto box. I want drain completely if poss. to fill with fresh fluid. I recon the auto would love that and may also sharpen changes a bit!. Cheers.
I removed the pan, you get about 1 to 2 litres, replace this with the same amount as you get out, also clean the filter while the pan is off, mine was filthy. Then take the line off the cooler thats coming from the box, start the car and pump out and measure 1 litre of oil, turn the car off, then replace it, keep repeating this until the oil looks clean.
Took about 8 litres for the oil to become clean.
From what i understand they hold around 12 litres all up.
just a quick one to all those after trans coolers i have just had some PWR >_< coolers come into Supercheap Auto that are priced at the same as our generic one $85 :D:yes: for one that is rated for a V8. If you are after one and have trouble getting hold of one PM me and i will get one for you
cheers
  • 2 years later...
that's clever... cheers for that
How about a variation... take the cooler inlet hose off, dunk it in a bucket marked 'old transmission fluid', and put this down low, say on the ground. Then, attach a length of temporary hose to the inlet of the cooler, and hold this in your new oil container.
...or, to make things easier on the trans oil pump, you could arrange a gravity-fed setup of a clear plastic bottle inverted, with the hose in the lid. That way you can even meter the level going in... I've never tried this but thought it could work?
Edited by DaveB
Hey guys it seems that nobody has asked yet, but is the trans cooler upgrade as relevent to series 2's? They appear to have a much more substantial cooler than the S1's simple "finned loop" - looks like a 'proper' radiator (same style as radiator), don't know my tube & fin from my plate & bar tho. Just wondered if the tiptronic needs something bigger than that?
Edited by DaveB
  • 4 weeks later...
I have finally fitted the large (Davies Craig) auto transmission cooler to the Stagea. The part number I chose was 678 which is the largest universal (280 X 216 X 19) I could find with 3/8" fittings. The catalogue specifies for engines "4.2 litres and over"
I will post up some pictures of the installation tomorrow. :D
For Kiwi readers this unit is available (by mail order if necessary) from Silverdale radiators for $149 +postage (saw it on Trade Me).
  • 1 month later...
Go into Supercheap and see if the 678 is bigger than yours. If not I read in a US car magazine a suggestion to go to the scrap merchant and get a huge heat exchanger out of an aircond unit basically for the price of the scrap value. Then you have to make up your own mounts and buy some hoses.
  • 8 months later...
Fitted a PWR cooler last friday. Was a rather easy task. I used the same bracket and just drilled an extra hole in the cooler and bracket the same as SK did.
Felt the cooler today after driving to work-30 min freeway drive and it was warm to touch but not hot at all.
Also looks mean from the front cos intercooler is down low then in the grill on the left you can just see the trans cooler :)
i still dont have one, my trans is waiting on gasket and filter before i can service it(getting genuine nissan brought in) i have a shit kit, and my fluid is as new, over 12months and 30k km on!
  • 4 weeks later...
Hi all,
Just thought I'd share that I visited MV auto's in Adelaide about my standard (as far as I know) trans cooler on my S2. It is pretty large, a lot more substantial than the S1's and possibly even larger than the Davies Craig jobbie in those pictures that SK fitted. MV's advice was that it was a good size and didn't require upgrading; only that it would need relocating if I was to fit an intercooler. Which I will do eventually... and a high-stall convertor is sounding more like a good idea as my GCG hi-flow turbo is lacking in stall-launches compared to the stock turbo.
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
