  • Replies 314
Yeah but they may require an external tow hook because your car may be burried in a sand trap. I dunno. I know you can get external tow hooks - I personally dont want to have to get one however.
I've got a nice shiny red tow hook for mine, haven't fitted it yet.. You can buy them at Autobarn.
Yeh, with my wiring loom out im soldering in my AVCR scramble button so it will be 1.2bar then 1.4 bar for the occassional hit in a straight line. Problem is im In Adelaide with work, and not having the greatets of time getting al the parts i need and time to finish the car.
Fingers crossed that this weekend the car will be back on the road:)
For peoples info - as of last night there were 35 entries. So still 35 spots left but they are starting to fill fast now. So if you haven't got your form in and you are thinking of joining us then do so shortly.
Also - as a super new cool toy for those dorky minded out there - the WRX Club will have available a wireless up to the minute race time monitor for anyone that wants to bring a laptop along. All it really menas is that you will get to see the times as they happen rather than waiting for the print outs.
http://www.racetime.com.au/rmonitor/
will show a directory listing with two files - setup.exe - around 730k and instructions.txt.
Anyone wanting to have Wireless Access needs to download the two files - read the instructions.txt and run setup.exe.
For anyone that is concerened - the RMonitor system will be installed ONLY in the directory nominated by the user (we default to c:rmonitor for ease of identifying it). NO files are installed in ANY other directory.
They will confirm the IP of the result machine on the day.
Ok - we met a few of the people last night. Seemed a decent enough bunch. We even ran into our good friend Tony Peter (Black STi)
We covered the few little quirky bits of their sup req's.
Tow Hooks - skylines have hooks under the front of their cars. This is acceptable. Nothing else is required.
Shoes - its seems they are a little more fussy on shoes than most people. They like the shoe to at least have a leather upper. Either that or you need to have fire proof socks.
Extinguisher Mounts - the spot that many of us have used in the rear seat is fine. But they wont be accepting any plastic brackets - nor any brackets that have been attached with either pop rivits or with self tapping screws.
I think that covers most of it. Still plenty of spots left. Not long to go now - Im getting excited.
Oh - finally - if anyone would be able to help out with Flagging for this event could they let me know.
:P
A few points. They surely mean fire retardant socks as fire proof wouldn't fit in any shoes. Mine are cotton drill uppers over cotton socks (go the dunlop volleys), much like the cotton clothing I wear as fire protection and meets all other sprint event sup regs. I'd agree if the shoes were to be fire retardant and they were consistent with other clubs. What's so special about these guys.
Since the self tappers and pop rivets are out then I'm getting the chewing gum ready, didn't say anything about that. Honestly, have they taken any engineering advice on this? Most of us have just one seat bolt through the mount and a self tapper, so will that fail scrutineering? If I use hex head self tappers I bet they won't check. Christ, aircraft are held together with self tappers and rivets.
Flagging...their party...my money...do you think I'm going to wave a flag for them.
If I sound a bit grumpy it's possibly due to the amount of panadeine forte I've consumed over the last 2 days, but mostly because they are being unreasonable.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
