After market ECU on a GTS25?
skyla
 Share
hiya all,
I have a R33 series1 GTS25 sedan which I have been slowly been working on over the last couple of years.
so far things that have been done,
K & N panel air filter
extractors
2 1/2" exhaust
manual conversion
nasty heavy duty clutch plate (you can't slip this one)
Installed a LSD
Front strut brace
king springs
bilstein shocks
white line rear sway bar
nolathane sway bar bushes
ROH adrenalin alloys (shadow chrome)
Mintex road/race brake pads
GTR rear spoiler, side skirts and end caps
I have a 400R front spoiler too, which I haven't had painted yet.
So the time has come and I have the erge to spend some more money on my baby. I have looked into many different options to try and and gain a few extra kw. I thought after market cams, a fuel pressure regulator and a safc would be the way to go, but found that the standard ecu would be the limiting factor in trying to get any decent sort of gains from the cams, and giving my stock cams a mild regrind wouldn't really yeild any noticable power gains.
So this got me thinking what if I spent my money on a new after market ecu, and use it as a base to work on in the future. After much thought this is the way I have decided to go, so I have ordered a new ecu (R33 GTS Link) which I should arrive in mid January, and hopefully will go into the car in late febuary.
So have any of you guys/gals replaced the ECU in your N/A skyline?
If you have, did it make much difference?
What about a unichip? i've heard they do good things for a turbo, what should i look for with a unichip or some sort of piggy back to get some gains..?
Can anyone speak from experience, or recommend any sorts of ecu systems that'll help??
Not to sure how rich the mixtures are on the NA RB25's.
If they are quite rich like most Nissans chances are you should be able to lean them out a bit and pick up some good mid to top end power.
I would imagine the factory timing would already be quite agressive if they were mapped to Jap spec fuel, so probally won't be able to add much more in that area than the factory ecu already has.
You should be able to pick up a little bit here and there though...
Do they require tunes and stuff done to them?? is there anyway i can buy one off someone thats just plug in and go?? how much of a gain can i see??
As far as I know they need to be tuned for the individual car, to get the best out of them. The ECU I'm getting is a plug in sort and will be set up first using a laptop and then fine tuned on the dyno. The guys selling the ECU to me, said that I should gain around 6-10kw with the addition of a tuned ECU on the dyno.
The ECU I'm buying gives me the option of removing the AFM, do you think this would be a good idea? Any one had any experince with a car with the AFM removed?
Yeah I think RB30-power is right in saying the A/F mixtures are rich, I have a A/F ratio gauge installed and it's always reads towards the richer end of the scale.
I've seen good results from ECU's on the RX8's from leaning fuel and advancing timing, this was in the US on some low-octane fuel too.
I can't see why an improvement couldn't be had on the RB25DE as well.
hey guys just some feedback and notes that ive read on the forced induction area
skylines are best suited for closed loop operation and using an air flow meter
theres jack all restriction from the air flow meter and removing it will give you nothing
you can inherit some bullshit problems and bad fuel economy from doing so (removing afm) as you usually use a map sensor instead im pretty sure.
also the cost to fit and tune an aftermarket ecu is a lot compared to gains achieved?
$1100 for power fc, $300 for tune and you get what 10kw extra?
most gtsts with power fc fitted and a shitty $100 bleed valve suck out an extra 30rwkw from ecu and tune much more resonable gains
have you guys considered turbo conversion instead of making the n/a faster
merli covered it once before and it does seem the most "cost effective" approach
just my 2 cents
you know the probably cheapest and best outcome
drive r33 gts25 n/a for 2-3 years or whatever once you are ready and have some cash
do an rb30 bottom end conversion and use a turbo manifold
cheap base car that hasn't been caned
rock solid rb30 bottom end
turbo head with new turbo, ecu, injectors etc
should be a real killer and make massive power
A bit of a gain can be made with the addition of an aftermarket computer with the added bonus of it running cleaner and more efficient. Keep in mind though a heavily modified N/A GTS will still struggle to keep up with even a lightly modified GTSt.
My advice, save the cash and do an RB25DET engine conversion. While more expensive in the short term, it will be far cheaper to extract more power out of it down the road. I did it on my R34 and have not looked back!!
My 2 cents.
Sounds like a plan, anyways, my skyline does me just fine as it is right now anyways... only my first car so i cant really complain... i dont wana have it for ages anyway, at the end of the day, i wana upgrade to an R34 either late 05 or early 06 when i have some driving under my belt, but even still... i want it to be a non turbo for the time being!
I'm fully aware that a lightly modded turbo will out perform a modded N/A. I'm lucky enough to own 2 skylines one a lightly modded turbo R32 GTS-T and the other is my R33 N/A, and yes in a straight line the GTS-T is quicker although at top end the GTS25 holds it's own and there's nothing in it and will slowly pull away from the R32. The truth of he matter is that I perfer the N/A over the turbo, and it's different, not many people choose to work a N/A, and I'm curious to see what sort of results I will be able to get, even though I know it's going to be expensive, and have relatively small gains for the amount of money spent.
As I said in one of my earlier posts I'm buying the ecu as a base to work on for future mods.
I have looked into doing a RB30 bottom end but have decided against it, and stay with the lighter RB25, and see what i can get out of it, One of my friends has put a RB30 bottom end into his car and last dyno he got 130rwkw and over 600Nm of tourque with extractors, pod filter, a 3" exhust system, and mine is currently at 112rwkw and 475Nm of torque.
Thanks for the advice on the AFM I have since done a search and found some info on the subject, and will most definitely keep the AFM.
When the Link ECU goes in I'll post up the results if people are interested.
thanks
Rach
 Share
    • Cheers, It must be close enough coz I can’t even tell where u painted. Did u do the whole top of the strut tower or just a patch somewhere?
    • Hey all. Looking for all of the carpeted trunk trim for my 95 GTST coupe. I’m having a hard time finding the pieces I need on US or Japanese sites/auctions and was hoping someone has a clean set stashed away somewhere?
    • New aerial is aerialing well....trips into Goulburn are not losing the ABC classic radio signal Also......I've been procrastinating about wheels for the MX5, the car doesn't need any more tyre, I just "want" different wheels, so I went looking for something that legally fits the new Pilot Sports +1 size 215/45 17 that I'm currently running on the 17x7 OEM wheels (stock size is 205/45 17), not a silver, and not a black, ended up with gloss bronze Konig Dekagrams in 17x8 +40 which fit without the need for rolling the guards, whilst larger than the OEM wheels they are also lighter than the OEM wheels, and at just under $1300 for the set I'm more than happy with the price I seen a set of matt black Deka's on a MX5 when I was at MX5 Mania, same wheel size, same tyre size, sat really nice, and not stretched enough to look aids, although the 215/45 17 is the smallest that you can legally fit Just need to find some good black wheel nuts to suit
    • So I decided that I wasn't happy with how I originally wrapped the loom with fleece tape. I didn't factor in the new intake manifold/plenum so it always sat a bit funny. Yep, I decided to unwrap it and redo how the wires would branch out. Added in a light twist too, here's hoping I didn't snap any 30 year old wiring because FML if I did. Took a few more photos of the shit box too, needed it for Enthusiast Insurance as they wanted photos to justify why my agreed value was above market by a fair amount.
    • if wanting reliability and that level of performance a dry sump is mandatory for circuit stuff as you'll just be filling the head with oil. easy and reliable setup with potential for more later Hypergear bolt on turbo or a g30-660 with T3 rear housing .92 external gate mod to factory exhaust manifold with 45mm waste gate plazmaman/pwr intercooler oil cooler 1200cc injectors 460 TI/walbro with upgrade relay and wiring/pwm control turbosmart fuel reg Link g4x plug in ecu with knock, oil, fuel pressure sensors, 3 port mac valve, DBW conversion Quality clutch kit- NPC is what I've used for a long time READ THE WHOLE OIL CONTROL THREAD Could do major service while there and maybe headgasket, studs and valve springs. as soon as you whack a massive turbo and short runner intake on a street car they are useless and not practical the above will be a fun and reliable 400-430hp on E85 all day with correct maintenance and mechanical sympathy.
