thanx heaps ylwgtr2, reading that makes me feel a lot better.
i had a closer look at it, and the damage wasnt done from a forklift. the damage goes across one side. it looks like it was beached (or what ever you call it)
ill try to take some more pics. i dont think theyll be able flatten this one out, its squashed down too much.
thanx again dude.
steve
I think you would be suprised at what can be fixed....at worse a new one should still be available...or at even worse....you could make that section of rail quite easy with the use of a guilotine and a bender...i made one once because there was a few weeks wait from japan,it took about two and a half hours to scribe it all out,hole saw the original holes and bend it into shape....the tricky part is there is an offset section with a flattened out part...just takes a bit of "blacksmithing"to shape it
  • Replies 48
Hey man, Cheer up you can look at it on the bright side of things atleast your cars got a healthy engine in it, and the damage wont be that hard to fix providing you have had a bit of mechanical experience and stuff before!!
My brothers car had damage kinda similar to yours, sept the difference was his was at the start of his chasis rail. Now how they fixed this was to drill all the spot welds off the rail, and make it a little more 'workable'. You should be able to jack the car up and basically un do all the welds, and put a large clap on the rail once done. When you've got to this step, you should be able to change the angle and mounting possitions on the clamp and heat up the rail with a oxy. Once this is done, and while still very hot (should be close to red if not red) tighten the clamps to force the metal back down and the middle should pop down fairly well! remember when doing this go that little bit extra because the metal will always come back! Weld the spot welds back up and your set. Once this is done do what ylwgtr2 said, and beat it up a little with the hammer getting a little more shape into it.
When you've done this grind it back a little and put some fill in there then spray it with under body spray (hides alot) and just give it a quick hit with some black paint again!
Shouldnt be too hard really, just takes alot of time!! If you dont feel comfortable with it, just take it to a panel beater, they shouldnt charge too much and should do a reasonable job, and like everyone else said, everythings fixable so dont worry what others say!!!
Take an easy, hope your happy with your gtr other then this!!
Dayne
by looking at the pressing of it and unnatural marks/lines created by the accident/damage......the only damage that will cause ill fated handling are the ones that mount suspension parts....this is unless the motor is 1metre further back than it should be creating an unbalance...altho 1 would assume this would be noticible :cheers:
Do you have pics of the undercarriage of the car before it left japan? If it wasn't there prior to shipping, and you shipped with an insured carrier (eg Kiwi) then you can claim the cost of the damages.
no they didnt give me any pics of the undercarrage, and they didnt say anything damage.
I guess ill be taking it to a pro. i dont want to try something like this on my own. Id do anything, but bodywork. i dont trust my self enuff.
anyways, thanks for all the info guys. i feel a lot better.
crap thing now is the money i had set aside for getting the paint mint has to go to this repiar.
oh well, importing is a risk well all take.....
steve
I think bennettaru might be asking which shipping line you got it here by, as the agent is rather irrelevant if the damage was caused when the car was moved for storage/shipping.
Judging by your avatar it was a Japan Auto Direct car (even if you bought through Prestige).
LW.
I would almost bet that the car was forkilifted in Japan, not here. I have seen numerous Jap cars come in with forklift marks of varying degrees of severity. Although as you say your's may not be a forklift mark at all, but caused by something else. Either way, I'd say it happend in Japan. Bummer.
Richard
yeah it sux, but at least its fixable. it looks like the money i have set aside to do up the paint or what ever, will have to go to fixing this problem.
at least the engine and box are good, the interior is almost perfect, cept for a tear in the drivers side seat.
I also found a pair of HKS super sequential bovs and a nismo 2 way diff so they were bonuses.
also the brakes are in real good condition.
oh well, the risks of importing........
steve
Just make sure you get it repaired professionally mate, cause after looking at those pics again it's pretty serious damage. you want to make sure you have a straight GTR when all this is over. then you will sleep much better :)
Guys if you think this kinda undercarriage damage has to do with shipping companies then you'd be wrong...
My car (yes $2,000 shitter) has EXACTLY the same undercarriage damage... and it hasn't even left Japan!!!!
This kinda dodgy sh*t happens right here in Japan, and don't think these dodgy bastards in the car trade will be honest about it. They'll pick up the car with a forklift for any reason at all... jeez I think sometimes (for example) the car hoist is already being used at the reapair shop so they just lift the thing up with a fork lift and try and fix whatever needs to be fixed... the Japanese are dodgier than the Artful dodger himself.
Rezz: I'm sure what you say its true, but it can be important for insurance claim purposes to work out where the damage occurred (though, IMHO, its an uphill battle).
Doubtless the shipping companies and/or storage companies and/or auction houses -- or any other of the people that get access to these cars during their eventual journey to Australia -- use the same methods as bad dealerships: wheel out the forklift, bugger the consequences.
LW.
Guest Mashrock
haha i have seen damage to almost every car that my mate brings into auz!!
its not from forklifts its from either mechenics or whoever owned the car in japan..
where ever they jack the car up from to change a tyre etc.
not much care is taken!
rezz seems to be on about something tho.
    • Thanks for all the replies fellas. Gonna finish putting it back together and see how it handles the set up. If it starts pinging it’ll be parked.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
