Hi,
I was just wondering if the process to change the Timing Belt in a R33 Skyline Series II is complex?
Where can I buy this timing belt from? I've got a mate who probably can do it but I dont want to ask him if it's going to be a lengthy task.
Also, what price should I be looking at if I was to get this done via a workshop/mechanic? Any suggestions on where to get it done (ultratune?)
Lastly any suggestions on what should be replaced so that it will save me Labour cost in the future (eg. water pump?)
Any help would be great. Thanks.
Regards
Steve
Also get the idler and adjuster bearing sets. There is a thread on these in the forum but if they go, then the engine goes. Mine had done 120000km and were pretty ordinary. About $120 for the NSK set. Use the search feature. Also might be worth changing the guide plates @ about $10 for the pair and the woodruff keys if they look a little worn for a couple of bucks, both from nissan. Ring NSK direct for a local supplier but don't use nissan for the bearings as they will ask for your first born and 2 fingers :D
also get the waterpump checked while they are in there. It will save you a couple of hours labour in case if it craps itself only a few thousand kms later and all the same stuff has to be pulled out to get at it again.
Have done the job in about 5 hrs with a mate (including farting about) the timing belt got from nissan the idler and tensioner bearing after market (got sell a kidney if you want nissan items) the cam and crank seals are all the same can get them from ACL changed water pump while was there saves headache later on careful pulling of the balancer it will be tight but does come off make sure to mark the sensor on the cam and when you take the front part of the vvt unit off on the inlet some oil will come out and its spring loaded dont loose the bolts
Hi,
Regards
Steve
When doing a timing belt replacement, its good practice to replace the water pump, and the idler bearing & tensioner bearing, and fan belts, eg power steering, alternator, so on. As it’s much easier to do it now once it’s apart, especially water pump. Because you could get the timing belt changed and your water pump could die in one month’s time.
And then it’s back into the garage pulling everything off again.
Idler and tensioner bearings you can get at any bearing place (Alard Bearings), Cost any where from $60 on wards. And as for the timing belt just go genuine, cost should be around $100 for a timing belt.
The biggest cost would be labor, as it’s a time consuming process. And that really depends on what your mechanic charges.
Hope that helps.
Steve the part numbers are PBT15 $40.00 and 56TB2801B01 $64.00 and the brand is called PART TECH if you take the numbers to a bearing place like CBC bearings etc.. they should be able to match them up the place i got them from is Mekong Spare Parts 9724 0691 if you any problems let me know
out of interest, has anyone seen a water pump fail on an rb? at how many klm?
I changed mine as well, but was just thinking, of all these threads on SAU I've never heard of a dead water pump ?
didnt you guys see the post were the dudes waterpumped housing sheared in half and threw the fan blade into the radiator, he reckond the belt was done up too tight or there was a stress fracture, it was nasty
  • 3 months later...
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
