These Kakimoto's
designed for the R32, they just look right.
I have a set with rubber for sale in gunmetal that matches your paint & offset.
they look better with the centre plate removed, the big alloy nut srewed back on minus the kakimoto logo - very street cred.
I'll post up a pic. Let me know if you want to trial fit.
  • Replies 51
i liked the Work rims to start with, but after having them on my car for a while now, im starting to dislike them. the design is good and the colour (gold with polished rim) its just that the spokes are really wide and dont go right to the edge of the rim. they are 18x9 and 18x10 and have mad dish, u just cant see much disc behind them and they look smaller than 18s. im going to get some Gram Lights 57 Pro's, they are made by Rays Engineering.
if anyone out there is looking for some 18" Work rims, the same as the gold ones above, off R33 gtst, gimme a pm.
cheers
Linton
oh and the 'trafficstar' 19" on FLYBYE (hpi issue 44) tickled my fancy.  but apparently there rare.  anyone know anything about them?  is the person who owns flybye on sau?
http://www.ozzytyres.com/mag_details.cfm?id=461
Also, FLYBYE is now known as TUFGTR and was at the Summernats making 659.8rwhp in HP heroes.
There are also another set of these wheels that look exactly the same but are called Axis - Deep dish at Ozzy Tyres:
http://www.ozzytyres.com.au/wheels_more.ph...id=53&mag_id=28
I already have VOLK CV PRO's on mine, but will be changing them soon when I revamp the car's paint later this year. Would love some stockers for that "sleeper" look if anyone wants to trade. :P
Hey I have good set r32gtr rims. Look on Unique Autosports site. Under second hand rims. May trade.
I think R34 GT-R rims would look extremely alluring. R33 ones look cool on a 32 too.
Personally, I don't think there are many rims or bodykits that look better on a GT-R than what Nissan intended - the styling is so "right" from the factory.
My favourite wheels are magnesium RS-watanabe RS8's, in either gold or charcoal, the one piece super light ones - but not really the look for a GT-R.... Followed by Work Meister's and R34 GT-R wheels.
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
