Hey guys,
I am moving soon and have an important question about car storage. I am very worried about getting a hosue that has no car port or garage, How bad is leaving your car in the sun and rain? does it make it age noticably quicker? Is a car port much better then leaving it in the open? Does the sun damage in the interior?
any information would be handy.. thanks...
https://www.sau.com.au/forums/topic/60823-under-the-elements/
Sun and rain most definitely damage the interior and the paint.
Sun dries out leather and also some plastics causing fading, cracking and brittleness.
Rain can carry nastive corrosive chemicals from the atmosphere which will fade and even pit paint. Cities with worse pollution or next to the sea are worse with this.
Unfortunately all cars will suffer to an extent as its not exactly possible to avoid it. Just best to minimise it by keeping your car under cover and cleaning at regular intervals. Sun shades for when parking on hot days are always a good idea (prevents people from seeing any inside goodies too).
Worst comes to worst, maybe look into car covers? No idea how feasible and effective they are as mine is always parked inside at night and undercover during the day.
Dont park your car under trees either thats bad as well. U get all the sap over your windscreen then your wipers dont work properly and u have to polish your windscreen,
Also parking under trees the leaves fall into your skuttle chamber and can cause rust becasue they slowley turn to mud seen it happen a fair bit even saw it so bad on one persons car that the whole front end was rusted out.
This is probably a bad case but after leaving my car out for a year ( not my choice ) my paint has faded and started oxidising ( too bad to polish out), rust has poped up, lots of shrinking of my r32 dash and trim around the rear quarter windows. The car was parked near the coast so that sea air probably wasnt real good for the car. If you have no choice buy a car cover. Theyre a pain in the arse but well worth it.
my car lives outside....it holds together well
Troy: you car is a R34 GT-R isn't it? In which case it will have relatively fresh paint anyway. Its when the clear coat layers start to break down over the years that paint starts to look dull and lifeless.
LW.
I reckon if you're going to have a nice car, you need a garage. Depends on where you live, but expect multiple breakins and even just shitty little kids keying it, etc.
For about 6 months I had my R33 outside in the QLD sun and the signs were starting to become obvious, although nothing happened to it like the above. 2-3 years like that and I know the paint may have needed attention.
Rain isn't a problem as long as the car doesn't have any leaks.. It's that tiny leak where the water always runs down and always sits somewhere hidden away that causes the probs.. That is where your rust will develop.
I bought a cover from kmart for $70 (just a standard "large" one).. it didn't scratch the paint or anything like that. I would be using that if its going to be outside for weeks at a time. If somebody starts ferretting around the car cover it might be a bit more obvious, its also a tiny extra security precaution.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
