MV Automatics here in Adelaide (1 Stirling Rd Blackwood 5051) put the shift kit in my car for $300, and they told me they have sold the kit to other auto trans companies across the country. (ring them (08) 8370 0430 to get a price and then see how much your local shop will charge to fit it.)
I also had them fit a trans cooler at the same time (heat is not your friend).
  • Replies 99
well another auto R32 driver here, but i think people are underestimating the drivetrain losses with the auto box
i made 132rwkw with 3" turbo-back exhaust, FMIC, filter, rb26 cams, and 12psi (running very rich)
my tuner suggested i would have approx 155rwkw if it were manual, based on what he has seen in his experiences, which is about what zoom magazine found when they converted the rb20 r31 to manual and picked up 20rwkw
saying that though, the off-the-line work is very easy to get consistently right and stalling the auto can counter for the lag by never being off boost in a drag race :(
i have noticed though that when you change the gearstick (eg from 1 to 2) there is a delay of about 0.5-1 sec before the gear actually changes and its a bit of a pain in that regard...
i would also recommend a trannie cooler which i have installed on my car
but i have never 'raced' a manual skyline so i have no way to compare its performance...
cheers,
Waz.
Is that $300 for valvebody including labour?
Yes that was drive in, drive away. Not bad when I estimated a normal auto trans service (which was due) would cost $100 anyway.
Re power difference between manuals and autos - have you taken into account the different dif ratios?
i find that auto is most of the time faster, i drive an man, and when racing faster skyline than myself, i will almost beat them cuz they short-shift (i dont shift untill i hit 7000,7100 if it doesnt hit limiter im not tring :P)
soo i guess it really depends on the driver and how good/fast he can shift but i would say 70% of the time the auto will come out in front
If you shift when you hit the limmiter you are probably shifting way too late anyway.
Next time you get it on the dyno get a printout of the torque, KW plotted against RPM to work out where you get most torque and a what RPM to change.
What is their respective diff ratios? I think my manual is 4.11:1
auto's are the bomb.. call me lazy i dont care... they arent too bad on the track ( except 4 over heating) u can downshift will a pull of the stickto 2nd or 1st or a press of the button for third.
i must say afta burning one gearbox out at a trackday i am installing a cooler on mine when i get it back.
manuals may b more fun, but i have had friends who have manual skylines drive mine and they were really surprised by the way it drove and the reaction of the turbo.
my only prob is getting rid of the jap spec speedlimiter (180km/h) ( if anyone knows how let me know)
I ran 13.8 @ 104mph launching at 2200rpm
complete stock auto box and ecu
180.3rwkw back in august
since then ive done; fuel pump, cai, better dump pipe, hiflow cat, custom straighter cat back exhaust, fully synthetic transmission fluid
also put in safc2, so would be interesting to see what the above with tuning will gain over 180kw
or even more so with hiflowed turbo, bigger injectors, shift kit and bigger trans cooler :P
Easy, what you need is a "frequency clamp" in series with the speedo feed to the ECU. As the kph increases the pulsing frequency (from the sensor in the gearbox) goes up, when it gets above a certain frequency the ecu works that out as 180 kph and cuts power. You use the "clamp" to stop the frequency getting to that point, say 175 kph. Since all of the gear changing and other stuff is well and truly over by then, the auto box works fine.
Fueltronics sell them, so do heaps of others. If you are OK with electronic kits Jaycar have this one;
wouldn just wiring a potentiometer in line with the pin on the ECU that recieves a speed input do the trick?
wouldnt wiring a potentiometer in the line permanently, also give you faulty readings of speed all the time
speed goes up speed goes down speed goes up speed goes down
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
