I find you will only be beaten by an Auto if you don't know how to drive your manual :D
There was a reason the GTR didn't come out auto.. auto is horrible.
AHAHahahaah Amen.
I am not a fan of Autos AT ALL...
I like to slap 2nd and skate past my automatic rivals.
Unless its a worked auto with a stall converter and shift kitted, i dont like it.
To me, driving a manual car hard (on a track or twisties driving) i have more control over the car. I can use compression to slow down, i choose when it changes gears and when it doesnt etc etc.
I think it could be dangerous if for example, you were doing some hard driving in the mountains, and you put your foot down in an auto and it was unpredictable when it kicked down, if it kicked down too late and you were not expecting it to, the consequences could suck.
Also, gives you something to do whilst driving, makes it more interesting !
  • Replies 99
I like to slap 2nd and skate past my automatic rivals.!
I think your rivals are already well ahead of you by then. The only reason you skate past them is that the run is over and they have backed off. Just think about the slightly taller diff ratio in an auto, when you are reaching for second they still have a bit to go in first. (So why would you have caught them by the 1st to second change)
From this it sounds like there should be hundreds of autos written off on those twisty hill runs, but for some reason they are never there when I go up. I'd be happy to buy some of the wrecks and get the go faster pieces.
Well apparently there were a few Auto GTR's.
http://www.skylinesaustralia.com/forums/sh...ead.php?t=61246
Also, when doing a hill climb you can use the HOLD button and it wont downshift unexpectedly.
i think we all need to agree to disagree! it seems like auto/manual is a personal pref. in two cars both equipped with the same mods, the auto may be faster in a drag depending on the manual drivers capability, however auto does suck for say track and the such.
Sorry buddy, thats where you are wrong - and if you race to 2nd gear, you are a retard. It is an art form to launch a high powered manual car properly, any idiot can launch an auto. I am sorry if you are unfamiliar with wheel spin.
I never said that cars were written off because of this, I just said its a situation i would not like to be in. If you state that you would rather an automatic transmission for twisty runs/race tracks - you have obviously never experienced a manual.
FFS :bs!: :kick:
I think somebody is playing with their gear stick too much
Auto is good when you don't want to control the car. Just sit there and stand on the accelerator. Where's the driver skill? The great thing about auto is that the car shifts for you, and you don't have to be bothered with changing the gears.
Heck, why not just not get in the car, and attach a remote control to the car. That way, the auto car is almost fully automated, you just stand by the side of the road and hit the green button to make it go. You even get to save that 80KG of fat your skeleton hauls around, improving the power-to-weight ratio.
No way, manual is the way to go.
I think a lot depends on where u do most of your driving.
eg. daily driver, going to work in city everyday stop/start constantly
I' d rather an auto. Especially, with heavy clutch.
For everything else eg. me going from suburbs to outer suburbs to work
everyday - not too much slo stop start = manual. Especially, cos I love
hillclimbs and twisty stuff.
Out of 6 cars, 5 have been manual (although the 1st was a column shift :(
so I guess its clear where my preferences are. Bottom line I was so glad to
get rid of that boring auto and get back into manual.
Saying that a car is auto so you dont drive it etc is a load of crap, all you have different is a clutch.
i can guarantee you ive spent/spend more time doing stuff to my car then you do (mainly cos im unemployed hehe) so saying i might aswell have a remote control is an insult to me.
All i have to say for those people who think autos are shit.. Have you owned or had the chance to use one properly? NO, so dont talk about something u dont know. Simple as that. :(
Slide: Revving and dropping into gears in any auto besides a racing transmission will destroy it pretty quickly.
The truth is no one has said the auto is better than manual, because its not, but its nowhere near as bad as all the knowalls say it is.
Auto or manual, the passion for performance and skylines is still there, Regardless of transmission. :burnout:
Another benefit of manual:
Halfway between woop woop and nowhere at 3.am and the starter motor shits itself.
Manual driver pushes a few metres, pops clutch and keeps on driving.
Auto driver has no signal on mobile to call tow truck and gets eaten alive by wild cops waiting for the sun to rise.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
