Ooh, red LEDs :bunny:
Probably the usual IC orientation issue, but I don't have the instructions with me atm...
Do you have the wire link that goes under the DB25 connector (hand controller socket) installed? From memory I think it is installed on the underside of the board or something; I did the same trick and I can't see it in your shot... but I can't see much (as u noticed) TBH :D
  • Replies 1k
Posted Images
Ooh, red LEDs ;)
Do you have the wire link that goes under the DB25 connector (hand controller socket) installed? From memory I think it is installed on the underside of the board or something; I did the same trick and I can't see it in your shot... but I can't see much (as u noticed) TBH :)
checked those i think, and i remember doing the link under the connector
When you say nothing happens do you mean literally nothing? Do the LEDs light up at all? Best to test with the handcontroller plugged in so you can look at its screen. Try turning the trimpots on the IEBC back and forth to see if there is any action.
Are you confident that the ICs are the right way round? and in the right places? If you look closely you will see that they have different part numbers:
IC1 (marked with dot ) cat# EZ8996 KC5387A goes at right angles to the DB25 (handcontroller) socket on the opposite side of the board with the cutout on top - facing the DB25 socket.
IC2 (marked with line) cat# EZ8997 KC5387B goes parallel to and near to the DB25 socket with the cutout on the left.
Note links LK1 and LK3 should be left out.
its all how i have it, just double checked then
holding the wires onto the battery terminals should be enough shouldn't it?
and no, no activities from the led's :D or the display :):(
  • 1 month later...
hi all,
im finally getting round to install my kit - a quick question.
it looks like the vent between solenoid and actuator is open to atmosphere, according to the figures in the kit - is this the way to go, or plumb it back to pre-compressor somewhere?
cheers,
sam
hi all,
cheers,
sam
That's correct Sam, that's how I've been running mine. There is a connection on the turbo inlet pipe (suction side) that I have been meaning to connect mine too just so it isn't hanging around the engine bay but I don't think it matters. It may actually be bad to connect it there... haven't tried yet.
so it runs just fine without plumbback ?
i suppose it's only very small amount of air that's going out of the system post-AFM.
anyone with plumbback care to comment?
cheers
sam
Yep like Dave says it should be plumbed back into the bov return pipe (as yours is a new installation you may have to make a fitting). There should be a restrictor in this line and adjusting the diameter of this restrictor will affect the range within which the solenoid operates so if the duty cycle is too high you can make the restrictor smaller or vice versa.
  • 3 weeks later...
  • 2 months later...
Does any one know were to get one of these tuned on Queensland? I have built mine and want some one to tune it on the dyno It has been calibrated and ready to go.
have you got a boost controller or a DFA? The boost controller doesn't need to be set on a dyno. Is it installed and wired up? Any shop should be able to tune a DFA - in principle its the same as a SAFC and they might just take a few minutes to read the instructions if they haven't seen one before.
if you're in south burnette, from memory there's only one good tuner near you and he's in hervey bay. no idea what his name is though.
seriously though, this is incredibly simplified tuning. Anyone who can tune properly can use this setup and i'd be willing to be that even most n00bs could pull something decent out of it.
  • 1 month later...
Hi all,
Was wondering if anyone in Melbourne who has done this could give me a hand installing the DFA into my 33? I got the DFA and Hand Controller units already assembled, they were given to me when I bought another car awhile back. In return I could help you polish your car.
Cheers,
Will.
  • 4 months later...
To all of you out there using the Jaycar IEBC & DFA's a few questions!
Has anyone had any problems / reliability issues with them after the initial setting up?
Has everyone had an increase in economy as well as a good power hike with this kit?
Would you recomend them?
:blink:
I used the Jaycar IEBC for about a year and it was very reliable. The DFA is a better version of the Apexi SAFC. I would only recommend it for a S1 Stagea, but even then you would need an Apexi SITC to do the timing and a Greddy Emanage would probably be better. For a S2 the Nistune chip would be much better value for money as it does the whole range - afrs, timing, speed limit removal, rev limit adjustment etc.
  • 1 year later...
Just skimming back through the thread here's SK's suggestions:
Hi guys, it is not impossible that is is a bad component, but (based on my experience) it is unlikely. Burnt resistors are a sign of excessive load (going through them), so I would work my way through the circuit diagram and check the components on either side of the resistor.
Let's give it a go using the circuit diagram on page 141 of Performance Electronics for Cars;
It's a 10ohm resistor that sits between diode 2 and and zener diode 2 in the power supply circuit comtrolled by reg 1. So I would be checking the polarity of D2, ZD2 and Reg 1 and the value of the 1000uf, 10uf and 1000nf capacitors. I have marked them with red dots on the cicuit layout below (page 137 of Performance Electronics for Cars);.
I know someone has already suggested it, but the problem is in the power supply circuit, so the first thing I make ABSOLUTELY sure of is that the polarity of the power source is correct. Test it at least 3 ways, such as wire colour, multimeter voltage in and multimeter voltage out. The test voltages are shown on the circuit diagram above.
Hope that is of some help:cheers:
And another couple of tips - make sure you have the exact correct cable to connect to the hand controller and DO NOT switch between maps with out turning the engine off. On my one I made sure of this by by-passing the switch so that I only had one map.
Thanks for the help! However, I cannot see either of the images you posted. Perhaps SAU's photo server is temporarily down?
Really?? I didn't know this! I even have a remote mounted switch in the centre stack so I could switch between boost levels! Dammit. What happens if you do switch between boost maps with the engine running? I've already done this several times, didn't seem to do anything (when it was working LOL)??
Also, to try and stop this thread getting any longer, if you wish, you can post replies into my own problem thread here. Thanks!
Also when you say "exact correct cable" do you mean there are other similar types? I've got a cable that fits perfectly and passes all data through, but are you saying there are copies or others that don't quite fit?
Edited by benro2
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
