just put the r31 on the dyno
stock computer, stockinjectors, engine capacity is 2.656 litres
on 1 bar of boost and the stock computer running 10:1 fuel made a cruzy 260-70 rwkw before the injectors run out of puff
hits boost hard at 3500 and full steam ahead at 4500
was on a dyno dynamics dyno at autosport engineer in kirawee mst have been about 30 degrees.. thats all i can add
very drivable and im very happy cant wait to get some injectors and turn it up to 20 psi and rev her out to 9k
done
https://www.sau.com.au/forums/topic/61398-xr6t-turbo-powered/
  • Replies 84
These XR6t turbo's are looking more and more interesting.
On the 3ltr I would hope the spool would drop to around 3000rpm.
With a 1.06 exhaust a/r or what ever it is.. Thats damn good response.. How can it be?
BUT.. What exactly do you mean by Full steam ahead by 4500rpm?
Boost hits hard at 3500rpm but it doesn't accelerate or punch you in the seat until 4500rpm? :(
They most certainly are , identical core as GT35R or known by some as the GT3540R . 56 trim 82mm GT40 compressor , 84 trim 68mm GT35 turbine .
The unique thing with this turbocharger (apart from the integral gate) is its .50AR TO4E comp cover , possibly optioned to feed 4L at low boost and have good response .
For anyone interested GCG is tooling up to make a .63AR integral gate exhaust housing for GT35R's as part of a low boost kit in the wings .
I will probably option mine with a .60 E comp cover and 82 or 1.06 turbine housing .
never had the old twin turbo setup on he dyno but at 1.2 bar it had less power than the xr6t cruzing at 15psi
ye its a big furker that is for sure
runs like this
2000 rpm .2 bar
3000rpm .2 bar
3500 rpm climbing
4000 .6 bar(starting to hammer)
full boost or whatever you set it at at 4800 and power jumps to about 240rwkw
makes some great power and has the big single sound
downside is
the cat i have has killed itself so ill replace it with a proper high flow one
What kind of tuning has it had done? DOes it have Cams/Cam gears?
I run the same power from my RB26 1bar stock turbos, stock ecu, stock injectors.
tunning nothing just a run on the dyno to check that its not pinging and has enough fuel
im going to get some cam gears cause that will bring it on apparently
he picked it up off a m8 for 1000bucks the bugga! lol
mostly see them go for average 1500 to 2000bucks........ to buy them new from ford u'll be up for nearly 3000 i think from memory.
Drama is actually getting one is difficult ....a) how many ford turbo owners upgrade theyre turbo? B) finding a wrecked one at a wrecker that doesnt want big bucks for it.....
Matt
am interested to whats the XR6T turbo is made from obviosly not a ceramic one how much boost can you run on those trubos what the size diff between a rb25 turbo and the falcon one???, how much work needs to be done on it to fit??
i dropped the car at tripple g (call glen on 0403606314)
took him a couple of days to do the entire instal
he might be making a jig of the manifold to sell a few xr6t kits
it has steel wheels so once i have injectors ill turn it up to 20psi
compared to a rb25 tubo i would say its 3 times the size
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
