  • Replies 376
Posted Images
are these deep cycle?
anybody with big sound system given these a test?
where on the specs does it says 600cca?
do they have warranty?
1) They are not deep cycle , they are gelcell .
2)Dont know
3)they dont say , they only say the 40a/h
4)I cant offer you a warranty as it is a wholesale price
Also does someone have a price and local source for the screw terminals???
T.
Go through the thread someone has bought some .
T.
i bought some oddesey terminals that come with allen key bolts than screw into these batteries,
i got mine from battery world near tempe on the princess hwy in sydney, there is many battery worlds around the state im pretty sure they all sell them.
for the pair it cost $18, they are large tapered terminals u can see pics that someone else has posted of them (transplanted from their old odessey to their new battery)
Im keen for a set of these terminals but the closest battery world is probably 3 hours away.
Could anyone pick me up a set and send them to me? I'll transfer the $$$ first.
:P
Received battery yesterday, thanks
Will try to put them on tomorrow
Do you need to charge this before first use?
or just plug and play?
Good to hear , it got there quick , just put it in , it should be fully charged .
I cant find a set of terminals either, checked battery world, coventry, repco, supercheap... none of them have it for sale seperately. Right now its installed in a rather dody maner (Nut, Bolt, Washers) if you get what I mean. Any ideas where I could get some?
they should have them, ask for optima battery terminals. I know battery world at tempe has them.
Yea they have the terminals for odyssey and optima, but they dont want to sell seperately... it comes as a package with the battery.
on another note, these diamec are awesome, cold starts even with a wolf is so easy now ahha
Sure? Ask them again.. Is this battery world at tempe? Coz I know they do it. Unless they have changed it since so many people go there to get them.
If you cant buy what you want , there is a couple alternatives .
Go to jaycar and buy eyelet terminals or cut your old battery's lead posts drill a 6-7 mm hole in the centre and screw them on the new battery and you have new posts . If you have the stock 33 gts the negative terminal has an eyelet so you can just screw that one on and you only have to worry about the + .
I hope that helps you in someway .
i got mine from battery world tempe as well. they had them in a cardboard box, no packaging, so maybe they only had a few sets spare. just call them.
oh and dont buy stuff like clamps from them they are a rip off, i got my wider clamp for $4 from repco.
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
