Im currently in a dilemma, I want an engine which is good for low down responce/torque and performance for everyday street use. Im going for 2530's or GTSS turbos. As for ECU Mines are known to make responsive cars, and I was told to go the mines ecu route, Im looking for about 550-600 bhp....but I am also considering the power fc
any tips advice would be welcome
https://www.sau.com.au/forums/topic/62297-power-fc-or-mines-ecu/
who will tune a MINES ECU??? the main thing when considering an ECU is what tuners are available to you, and what do they specialise in? You are in London? I read an article from your Japanese Performance Mag, on the autronic ecu... Best bet is to find the tuner you want to use, and ask what he prefers to tune, and there is your choice.
firstly are the gt2530's still available? i know that many of the GT series are discontinued. They are rated at 320ps each and would be perfect for the power you want, and you can still get them 2nd hand.
The GTSS's would be awesome for response, but are rated slightly less at 280ps. but im sure if you get a pair of them setup and tuned you wont be complaining!
Power FC i believe is really your only plug and play option and used with proven results here in Aus, but as said above, you tuner has to like it.
ok ecu got to be power fc an awesome unit and easy to tune to what ever setup you like throught hand controller or datalogger.
turbos your on the right track but there is also the ball bearing garret 320hp turbo which is very similar to the 2530s but maybe a bit better responce down low and a little less high boost(1.7bar) capabilities (ownly my opinion) a very good compo
with these to mods you might want to consider rb20/25 afm(cheaper than z32 and good to about 540rwhp) and 700cc sard injectors ,cos as you tune up the setup you will fast run out of fuel (injectors) and air flow monitoring (afm)
hope this helps
get the PowerFC
you'll never regret it
If you don't live in Japan or have access to someone with experience with re-programming the Mines units, you would be nuts to choose one. Even if you did have someone that could re-program it, the hassle just isn't worth it IMHO.
Power-FC all the way.
LW.
Power FC all the way..
Lots of people use other ECU's and have issues with things like Cold Starts (applies to you) running air con (applies to me) and getting good smooth idles with alrger injectors. POwer FC's are beign used all over the world succesfully, the only downside that I can see to a Power FC (minimal if tuned well) is that they don't have effective tempeterature compensation, as I said this can be tuned easily and with excellent results..
Also take into account the FC-Datalogit package where you can modify all the options in the Power FC, that you can't do with the Hand Controller, like Fan switch on temps below 95 deg.. also you can then have launch control and extra intputs as well as full logging and view the whole map at once.. Check the FC-Datalogit website.. http://www.fc-datalogit.co.nz/
I was going to go with either a Power FC or a Wolf 3D V4, but after a few comments from people with the Wolf's I decided to go with the Power FC.. THis is being tuned in February in Perth and I will be picking up a FC-Datalogit shortly afterwards.
  • 5 months later...
    • So, I started this repair and got as far as "fixing" the holes with some fibreglass. God all those years working on boats came back quickly. I decided I'd reach out to some rust guys just to see what they would say about it. I came across a guy about 40 mins away and went to see him. He said the windscreen needs to come out, that there might be some more bits around the windscreen and he'd quote them at the time. But his quote was $300 to remove and replace windscreen and $3k for the damage he can see. He said he could respray the roof for $1200 and the bonnet for another $800 (somebody has previously rattle canned it, its horrendous). This is $5300 + any small additional bits. It's a lot, I get that and the name of one of my fave youtube channels 'Not Economically Viable' comes to mind.  I'm not being financially rational, but I've taken him up on the quote. He's opening a new shop in November with more room, so we're waiting for that. I'll leave the currently missing headliner out until then. I'm looking forward to it being fixed and having the paint looking nice again (lots of clear coat issues on the roof too). / flame suit on.
    • Oh and some up-and-comings; New rear drivers wheel bearing. I'll do that this weekend while the diff is out. The car is already up and the d/c axles and missing exhaust will help with space. This is the last bearing for me to do and I've been dragging my feet on it. I also have some new EBC blue stuff pads for the car and some new brake fluid. I haven't ever flushed the fluid in this car and looking forward to it. I have 600 degree fluid to put in. Not exactly "race fluid" but better than the typical stuff I have been using.
    • A proper clutch/plate type mechanical diff with quite a lot of pre-load and high locking % is better for drifting. Much more consistent in its behaviour. A helical can be annoyingly vague and inconsistent in how it responds under the sorts of abuse found in drifting.
    • Some updates here. I pulled the entire interior out, minus some trim to respray the seats with Colourlock dye. It turned out really nice though I accidentally let the dog in the car after and she scratched up the front seat.  This is what it looked like before, the colour was just washing out everywhere but thankfully the leather was in good nic. Then after the respray   And after the bloody dog jumped in The headliner is out waiting to be retrimmed, but it will stay out now until Nov - see why below. I replaced the stereo/headunit with a period-styled Android headunit. I have no after pics, but I'll get some. This is because of the missing pixels. I tried to fix this twice with replacement ribbon cables but couldn't. Also the bluetooth interface I'd bought for this was crap. Then there's the rusty roof. Pics and info in this other thread. I have decided to get this repaired professionally, but I'll update that thread. This is why the headliner will stay out for now. I'll be getting the roof and bonnet resprayed at the same time the rust is fixed. I also had an interesting issue with my drivers door lock.  For a small period I was having issues getting any 12v power to the car - I mean *any*. It would have no dash lights, nothing. It happened while I was at the shops and I couldn't get in the car. So, we had 2 problems. The most pressing here is that I was locked out. I have only a single physical key hole on the car, the drivers door and no amount of turning would unlock the car. Surely it doesn't need power for this? The second issue is why am I losing all power periodically, The battery isn't dead, its almost like the battery isn't even there. Two issues that were surprisingly easy to fix. You fellow BMW over-engineering lovers will appreciate this. The lock in the door has 5 states; mechanical lock, electric lock, neutral, electric unlock, mechanical unlock achieved at -90 degrees, -45 degrees, 0 degrees, 45 degrees and 90 degrees. Although, the unlock is towards the front of the car, so opposite for LHD countries. Sticking the key in and turning 45 left or right is what is used 99% of the time. It activates the central locking etc. 90 degrees is for dead battery access and, obvs, only un/locks the one door. But because the mechanical lock is never used and is 27 years old, it seizes up. I was totally unable to turn the key far enough to get to the mechanical unlock (At the time of locking myself out, I didn't even know this was a thing). I eventually did it with some vicegrips and teflon spray.  I made a quick vid for other E39 peeps.   The battery issue is totally new to me also - It wasn't making sufficient contact between the post and the terminal. The terminal was bolted on tight, but the car wouldn't have power. After checking the battery with my multimeter I accidentally contacted the terminal and the battery post and the car got power. The battery was only a few years old and in good condition. I cleaned the post and the terminal with a wire brush, bolted it back on tight and never had the issue again. I'm still surprised that despite having solid contact it didn't work. Also, the car was getting Warragamba sized pools of water in the back when it rained. My initial concern was another rust problem. But when I went out on Weds while it was raining and while I had no headliner in I could see a steady stream of water coming through the roof mounted aerial. As this aerial is for the (now removed) car phone I pulled it out and whacked a blanking grommet in the hole. It seems fine now. I'm thinking I might get the hole permanently filled when the rust is fixed. Moving forward and things in progress; The tailgate needs some attention. I have taken all the trim off to clean it all and address some small rust spots. I have partially done all of this but I'll finish it up hopefully this weekend. As all the trim are now entirely devoid of trim clips I have bought a heap of strong velcro and I'm hoping it does a good enough job as any of this trim in good condition is super expensive and usually in Europe as we dont have many of the wagons here. Suspension and brakes!!! This is exciting. In the front; New control arms New sway bar links New lower Eibach springs (the only modification I'm planning on this car) M Sport shocks (these came with the car and will replace the longer shocks in the car) New top mounts Used 540i calipers (stock brakes suck!) New 540i disks and pads (22x296 mm for 528 and 30x334 mm for 540i) New front wheel bearings (thank all that is holy for bolt on bearings!) Annnnd in the back; New control arms New sway bar links Adjustable air suspension arms (fool the car into what the current height is so the self levelling suspension can match the new front ride height) New ball joints I'll also be doing a brake fluid flush while I'm in there. I'm planning on switching the car over to the 16's that came with it so I can clean up and respray the M Sport 17's. They've lost a lot of colour over the years and have some gutter rash. None of this will start until the E90 is back.
    • You mean you will regret it for drifting duties? I don't quite follow.
