I wouldn't take it to TM, a few friends of mine have taken it to TM and each have come back with more problems.
The recent was they didn't do up the rocker cover and oil was spurting everywhere and a pool had formed in the Spark Plug area.
I would possibly try Hornsby Nissan, they service Imports.
Post how you go cause I need one too.
cheers.
Get some time off,,, have a nice drive down to Sydney and get Powerplay to do the job. I work in the Industry and loved their work. You might pay more than some other places but you won't be dis-appointed.
Neil.
took my ceffy down to Bel Garage in strathfield (bit of a drive for you tho) and they did the whole thing for $650 with a full fluid pump out, clean and refill, for things like diff oil, gearbox oil etc. Replaced the engine fan as it had a small crack, replaced water pump, changed the bushings that were worn, replaced all the belts, changed the sparks n checked the coils, did the full diagnostics using the nissan unit and then fixed anythign problematic that it showed.
Not bad service as well... he was quite amused to see a SAU-VIC car in NSW gettin a service tho.
Here is the full list that UAS does.
# Systems Check, reset memory, check all sensors and check for any fault codes.
# Systems cleaner, (pressurized can with long bendy hose inserted in various locations to clean carbon
build up in plenum chamber and tops of valves and ports as well as PCV and throttle body (s)
# Online injection clean.
# New Iridium Spark Plugs.
# Compression test.
# Water Pump.
# Thermostat
# Cam belt
# Drive belts.
# Oil Filter
# Fuel Filter
# Check cam and crank seals for leaks usually OK
# Check cam belt pullies.
# Check electrics, exhaust, suspension. Coolant hoses.
# Gear oil 75w- 90 or if auto trans service extra $100.
# Engine, gearbox and power steering get Uniglide treatment.
# Clutch and brake fluid flushed and bleed.
# Radiator and engine flush.
# Clean and treat battery terminals.
# Clean terminals to injector plugs, ignition coils.
# Spray lubricant on throttle linkages and other.
# Check and adjust water sprayers and additive used
# Lubricate door hinges and strikers, bonnet latch, boot hinges, aerial mast.
# Check and tighten sub frame and suspension and cross member bolts etc.
# Tyre pressures checked and corrected.
# Air filter replaced or if performance filters cleaned and re oiled.
Of that the only things i'd "professionally" need done (or havent been done within the last 10,000km/6mths are:
# Compression test.
# Water Pump.
# Thermostat
# Drive belts.
So that's 26 jobs down to 8 (unless you've never had a mechanic touch your car over the past 6-12mths in it's 10yr life which is highly doubtful) of which half are just 'checks' and the other half are straight forward work or 'if required' jobs.
Maybe you should take a closer look (or ring around and find out exactly what they do) then work out what you can do yourself and whatelse actually 'needs' to be done. Then re-ring places and get a quote on just those jobs and I believe the price would atleast halve (or atleast your local john smith mechanic could do).
Just my 1/2 cents worth, Does anyone know if POWERPLAY or UNIQUE AUTOSPORTS is better ? Not many d1ckheads u can trust with an import nowadays.
I haven't had much done at UAS so I can't comment.
But Alastair over at Powerplay does an good and thorough job :( they did my 100000klm service a while back.
BTW I'm not sure but I suspect they will need your car for a full day to to the 100000klm service so Saturday may not be possible?
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
