  • Replies 80
this is going to be interesting .....
for high reving ..joy riding and thrashing .. Rb20 would be my preference
but for pulling power , punch and off boost driveability .. Sr20 does pretty good for a 4cyl job .
just my thoughts
Matt
My flatmate has a rb20 r32 and I have a sr20 cefiro.
His car struggles to get up the hilly street we live on in 2nd whereas mine tears up it (both off boost).
I love the sound and urge of the rb20 as it gets revs but to me to get anything out of it you have to rev it, and so i find myself having to thrash it to do anything.
My sr20 is a pleasure to drive under 2000-3000rpm pre-boost and it drives like a bloody fast 2litre pre-boost so i prefer that.
I like rb20's, having had one for a couple of years. But the SR is a better base engine in my opinion.
It's lighter, it has more bottom end torque, it's smaller and after market goodies are cheap as. And they make the same power near enough so that seals it.
I like SR20's because they are very snappy & the pull hard & they are very quick for a 4cylinder, the only disadvantage is because its an alloy block they fa#king expensive to replace if you blow your motor up. Thats why most people put RB20's into their silvia because its cheaper and a good power gain because of power to weight factors.
Another disadvantage with the SR20 is because again its an alloy block it can't be used in certain 1/4 Drag Racing classes - Look at (mark ashford -spelling?) 200sx, he had to go FJ20 because the SR is alloy block and is not aloud to be used.
RB20's are good because of their nice smooth reving & the ability to sustain high rpm in standard form.
--Thats all for now keep the thoughts coming-- arguements aloud. ;)
Jun
I have owned both SR20 and RB20. I like RB20 for its hi reving capability. But then again it has no torque with the factory turbo. Whereas the SR20 has great torque. Is it the turbo doing all the work ? or does the sweet crap all torque get interupted because of the old crappy turbo on the RB 20?
Interesting thread RB vs SR well you could almost call it Torque vs Revs as these motor configurations (bore and stoke) are designed for quiet different charactorists.
SR is a light ,compacked and great torque
RB has awesome bang for bucks and is a great base to big a 2.4lt off as gtr rods and crank are cheap and you then only have to buy tomei piston ,which no matter what engine you have if your look for performance a good set of piston is essential and i thing the torque of the combo would be awesome, i know you can stoke SR but i dont believe any where near the $$ of the RB.
both motors are top notch (long live the turbo nissans)
I myself am having play with the smaller almost forgotten bother CA18DET and have seen a s13 CA run 9sec in japan, so i think i should be able to extract some good ponys out of it ,i will post results when done. :wassup:
I will have to say SR20.
The S15 Blacktop SR20DET engine is amazing, the responce and torque delivery is a lot better than the RB20DET (but there is a very large age gap there, and huge price difference)
On Sunday I was talking to a driver of an S13 Circuit car. And he went on to tell me he thinks the SR20DET (his was a old redtop, he said very little internal mods) was better than any RB motor for lasting power for a circuit car..
He said he was making 700 crank HP and that to have a car with an RB setup like his car would never go as good.. but he said it was more the torque which he liked. I don't recall the figure.. but it was A LOT of torque for a 2L 4cyl..
His dad however told my friend that this car would only last 5 meets.. i think an RB26 making 700HP would last a hell of a lot longer..
He was from the deep south.. so probably a bit backwards :)
What are some of you circuit racers opinions?
IMO the RB20 only do better than SR is smoother, the SR is a bit rough.
The RB sounds better too...
But other than the SR is better at every area.
lighter & shorter allow it to sit closer to the firewall for much better balance, handling and stopping.
it perform better both on/off boost, and late model SR also have VVT.
more torque is obviously the most important issue for shooting out the corner, i agree the RB might able to rev higher, but why need to rev the shxt out of it when u can get it in lower rev?
i am interest if someone can post up some dyno to see which engine has wider power band.
when someone say RB20 is cheaper to build, i am not really sure, since we are talking 6 piston, rod, injectors and SR is only 4.
previously own a R33 RB25 and the S15 SR20 is possiblily to compare with it.
4G63
case closed.
there was a similar thread in here somewhere where SK and _OMG put in a great deal of info about the RB and SR.
both guys know a great deal about their chosen engines..
kinda turned to a sh*t fight but it was good while it lasted.
maybe search for that and have a read.
You are joking aren't you?
Horsepower = torque X rpm
So what if the SR has Xlbs more at 4,000 rpm, it's a dead duck at 7,500 rpm. The RB20 is going strong to 9,000 rpm. It's simple maths. There is no way an SR can produce 20% more torque than an RB, but the RB can rev 20% higher. So the RB will always have more horsepower as long as everything else is equal.
Let's get down to the block issue, is there anyone out there who really believes that a standard SR alloy block can handle more boost than an RB20 cast iron block? Like it or not, boost = torque. So the RB wins again, it can handle more boost therefore it CAN make more torque.
This "SR's make more torque at lower rpms than RB's" is crap, any extra torque that an SR has is purely due to the tuning. Take a look at the stated torque outputs of the various models of SR's. The amount varies by more than 15% and the rpm by more than 20%, but they are all SR's. The difference is in how they are tuned, not that the SR design is somehow inherently superior.
It's a self fulfilling prophecy. You can't rev SR 's higher, so you choose components (turbo size, cams, porting etc) and tuning that work within the rpm limits. Oh wow it makes more torque at 4,000 rpm. Dah, it has to, 'cause it won't rev. If I tuned an RB the same, it would make the same, But I don't have to, 'cause I CAN get the RB to rev withoit spending big bucks on the valve train.
I could also get into rod stroke ratios, main and big end bearing speed at rpm, valve area, inertia mass etc etc. The bottom line is, for the same capacity, more cylinders = more horsepower. That's why F1 engines are V10's, not V8, or V6's or I4's. And nothing "shoots out of a corner" like an F1 car.
That'll get the SR lovers all stirred up.............:D
lol, this isn't a mitsubishi forum... GTFOH
don't get me started on how good the '63 is.....
i'd go the RB, just coz it's cheap to replace, doesn't matter if u blow it up - a very good criteria if you're gonna drift it - sr20's aren't as bulletproof as an rb20 and also 2-3 times the cost
You can't really compare the rb20det with a late model SR because they stopped making the rb20's in 1993. If you want a fair comparison, compare a VVT SR20 with a RB25DET Neo - or compare a rb20 from an r32 and an sr20 from an s13.
Let's get a couple of things straight, #1 I have more SR's than RB's right now. #2 I have more Chevs than both added together and I have more Hondas engines than Chevs. So RB's can't be classified as my "chosen engine".:D
as I said, 4G63 is where it's at..hahahaha
Oh no, not another one that is kidding.....
Only Mitsubishi could be stupid enough to have MIVEC technology and not use it on the 4G63. With a proper variable cam timing and lift top end, it might be a reasonable engine. It takes us aftermarket enthusiasts to do job properly and put 4G63 bottom ends under Cyborg cylinder heads. That's makes a silk purse out of a sows ear....
Yeh, I know, I should post it on the Mitsi forums for a stir.....:D
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
