I might be wrong, but i think my r32 gts-t s2 has a resistor pack on the pass side strut tower.
I am hoping to remove this and replace it with a gtr one that should arrive tomorrow. I also changed the plugs to bosch ones, they are much nicer and come on and off without the fuss of the standard ones.
  • Replies 153
I will be installing gtr injectors and r30 resistor pack this week before my tune on thursday and just want to make sure this is the correct way. Can anyone confirm that this pic i made is the correct wiring? :)
Also, it doesn't matter which injector is wired to each wire on the resistor pack correct?
Thanks
Dont know if this is the same thread I posted in before, but Ive been running my RB20 since May with GTR injectors with the Apexi ECU and no resistor pack. Works fine. Others have run the same for years and no problems. My car was tuned at Pro Auto here in Hobart and they have done loads of cars. None of us that race them here in Tassie run resistors, one bloke had them and took them off.
3rd Place Targa B 2008
Edited by johnGTS-t
AP Engineering power FC?
i would like to kno if this will work too, saves a lot of time with re wiring thats fo sure!!!
The resistor pack on the passenger side tower is for the fuel pump speed controller.
  • 1 month later...
ok so if i put r33 gtr injectors into a rb20 and have 6 inline resistors (one for each injector)
ie dont use a resistor pack - but use jaycar or something ones instead
anyone know what which resistors i'll need?
if not i'll just measure resistance in current ones, then gtr ones and then get resistor to make up the diff?
thats the ohms - what about watts?
I strongly recommend you get your hands on a copy of the R32 GTST/GTR wiring diagram. The fact that the two engine types are on the one wiring diagram makes it very easy to suss out the wiring. You can get the diagram from rb20det.com or megalla.com
anyone have this???
edit: oooh oooh ive got the R32 engine manual pdf - which has rb20det and rb26dett
  • 3 weeks later...
hey guys i had my GTR injectors cleaned and flow tested today all came up sweet, i replaced the pintl caps o rings and the other couple of rubbers require so all is good to go. does any one know where i can get the resistor pack from? im located in Adelaide the dude i bought the injectors off said that the injectors were low resistance does that mean that there are different types of gtr injectors? mine came off an r32 gtr. just curious.
can some one supply me with a picture of the ballast resistor pack and a picture of where to mount it in the standard position. id really appreciate it as i have no idea lol.
cheers guys BEN
Edited by BENDERS32
Ben - no afaik all R32 GTR injectors are the same - difference is the resistance compared to R32 GTST ones
I had mine (the GTR injectors i bought for my GTST) leak and flow tested on the weekend and put them in on the weekend
(and didn't have a resistor pack so made one)
think of it like this
R32 GTST injectors have a running resistance of ROUGHLY 12 Ohms
R32 GTR injectors have a running resistance of ROUGHLY 2 Ohms
so to make the GTR ones work in the GTST you need to add another 10 Ohm
so for each injector you add a 10 Ohm resistor
ps. sorry have no pics of said GTR resistor pack as ive never seen one and dont have one :P
  • 2 months later...
Does anyone know if you can run low impedence injectors in an rb20det silver top with a microtech lt12s ecu without doing the resister pack??
is there a function in the computer to set low or high impedence???
  • 1 month later...
Hey roy,
Thanks for the great tutorial. Helped heaps. Was a little confused when my resistor pack only measuered 6.7 ohms but checked it against a mates gtr pack running in his car and was the same. I can see why some people say that they have low impedance injectors without the ballast resistor. Throughout this topic it is stated that you need to make up the difference which is roughly 10 ohms. Not true..... The standard resistor pack out of a 32 gtr measures only 6.7 ohms so with the gtr injectors it only comes to roughly 9.3 ohms give or take. Elsewhere I've read that high impedance injectors run between 12 and 16 ohms which makes sense because my GTST injectors measured 14.4 ohms. I installed my resistor pack and gtr injectors two days ago then drove alll the way too sydney without a problem. Just wanted to put some figures out there so people know roughly what to expect. Any questions just PM me :(
Thanks again ROY, absolute legend for the tutorial :thumbsup:
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
