Automatic Transmission Shift Kit. - Updated Oct 2006
Ive been speaking to mike for the last week or so and he has got valve bodies for r34's only prob is he only has a couple from what i understand and i know ones mine so get in quick or you will have to wait for ppl like me to send valve bodies back lol
I believe stock is 1800. To check this out put the car in Drive, put your foot on the break and gently press down on the accelerator.
The revs should quickly rise to about 1800rpm, then slowly up to around 2000rpm before the rears tyres start to spin.
Hope this helps.
  • 4 weeks later...
Just wondering like many others here, is there gonna be another group buy on these shift kits? Also can u feel the difference once these are installed? Is it ok for a daily driver or is it rough? Thx!
stock torque converter is 1500rpm, which can be taken to 1800rpm with foot on the brake
his ideal upgrade (that he recommended to me, thus what i have) is a 2800rpm converter, and can be taken just over 3000rpm with foot-on-brake launch ;)
The group buy is still running, just phone Mike at MV automatics, tell him you are after the Akylines Australia price on the shift kit / Torque converter or both, and he will send them out.
It is fine for day to day driving, (gentle pedal action) but you will notice a big improvement when you plant your foot quickly
Valve body arrived today with transmission cooler, just trying to figure out which auto workshop to go to, does anyone know any workshops in melbourne around the s.e suburbs which i can go to? and what price am i looking at to get it installed, trying to put in b4 friday because i want to drag it on friday. thanks any help much appreciated.
Put mine in last night
sending back valve body next week
so if you are after shift kit for your R34/stagea (tiptronic) get in quick
It was very easy to put it in
and makes going around corners interesting
so are you happy with it? does it feel better to drive? im putting mine in tomorrow and hopefully go to calder tomorrow night and see what it can do.
well the shifts are more direct now
no more flaring into gear
I bought it more for the life of the tranny
Ill be upgrading turbo ECU and Injectors soon so i thought i better try and fix the transmission side of it before i burn it out
any mechanic can put one in, its nto rocket science, just requiers a hoist and half a brain.. (ok maybe a quarter of a brain...)
getting it put in today for $220 with a service and the transmission cooler put on, and since i don't have a hoist and my car is to low to get on ramps i have no other choice otherwise i would have done it myself. i will let you know how it goes looking foward to getting it back, the auto shifts have always shit me the cars got the power but i agree it flares to much but i have always liked the way the car drives so hopefully if it doesnt flare and i will be really happy.
shifts are alot better no flaring on changes, very happy with it feels alot nicer to drive really have to play with the accelarator now it spins alot on gearchanges overall im pretty impressed.
the installation / removal photos have dissapeared from this thread, does anyone have any photos of this process, which bolts etc ??
Can I pay for an exchange, change it over once I recieve, then send my std one back to MV? Or is that, I will recieve a refund once I return my std valve body to MV?
What a frustrating day, i installed my shift kit, no go, wont engage any gears, but feels like its in drive not matter where the stick is, pulled it out, re-installed it...ahhhh, help me someone, i installed the lightest, thinnest spring on the end one where the black diaphram is, blocked off the middle 2 ports with welsh plugs, what else is there to do ? any photos or advice please.
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
