Automatic Transmission Shift Kit. - Updated Oct 2006
Ive been speaking to mike for the last week or so and he has got valve bodies for r34's only prob is he only has a couple from what i understand and i know ones mine so get in quick or you will have to wait for ppl like me to send valve bodies back lol
I believe stock is 1800. To check this out put the car in Drive, put your foot on the break and gently press down on the accelerator.
The revs should quickly rise to about 1800rpm, then slowly up to around 2000rpm before the rears tyres start to spin.
Hope this helps.
  • 4 weeks later...
Just wondering like many others here, is there gonna be another group buy on these shift kits? Also can u feel the difference once these are installed? Is it ok for a daily driver or is it rough? Thx!
stock torque converter is 1500rpm, which can be taken to 1800rpm with foot on the brake
his ideal upgrade (that he recommended to me, thus what i have) is a 2800rpm converter, and can be taken just over 3000rpm with foot-on-brake launch ;)
The group buy is still running, just phone Mike at MV automatics, tell him you are after the Akylines Australia price on the shift kit / Torque converter or both, and he will send them out.
It is fine for day to day driving, (gentle pedal action) but you will notice a big improvement when you plant your foot quickly
Valve body arrived today with transmission cooler, just trying to figure out which auto workshop to go to, does anyone know any workshops in melbourne around the s.e suburbs which i can go to? and what price am i looking at to get it installed, trying to put in b4 friday because i want to drag it on friday. thanks any help much appreciated.
Put mine in last night
sending back valve body next week
so if you are after shift kit for your R34/stagea (tiptronic) get in quick
It was very easy to put it in
and makes going around corners interesting
so are you happy with it? does it feel better to drive? im putting mine in tomorrow and hopefully go to calder tomorrow night and see what it can do.
well the shifts are more direct now
no more flaring into gear
I bought it more for the life of the tranny
Ill be upgrading turbo ECU and Injectors soon so i thought i better try and fix the transmission side of it before i burn it out
any mechanic can put one in, its nto rocket science, just requiers a hoist and half a brain.. (ok maybe a quarter of a brain...)
getting it put in today for $220 with a service and the transmission cooler put on, and since i don't have a hoist and my car is to low to get on ramps i have no other choice otherwise i would have done it myself. i will let you know how it goes looking foward to getting it back, the auto shifts have always shit me the cars got the power but i agree it flares to much but i have always liked the way the car drives so hopefully if it doesnt flare and i will be really happy.
shifts are alot better no flaring on changes, very happy with it feels alot nicer to drive really have to play with the accelarator now it spins alot on gearchanges overall im pretty impressed.
the installation / removal photos have dissapeared from this thread, does anyone have any photos of this process, which bolts etc ??
Can I pay for an exchange, change it over once I recieve, then send my std one back to MV? Or is that, I will recieve a refund once I return my std valve body to MV?
What a frustrating day, i installed my shift kit, no go, wont engage any gears, but feels like its in drive not matter where the stick is, pulled it out, re-installed it...ahhhh, help me someone, i installed the lightest, thinnest spring on the end one where the black diaphram is, blocked off the middle 2 ports with welsh plugs, what else is there to do ? any photos or advice please.
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
