Well i am getting my R32 GTR rebuilt this friday (well starting anyways) at Racepace.... i have been advised to do a standard rebuild as i will be using this as a daily driver and not a sunday toy car, hence forged pistons were not recommended due to rattle and need for warm up. I think problem is the main bearing. anyway, will find out exact problem once he pulls it apart....
One thing that has got me stumped is whether to upgrade the turbos or not.....
Ideally i dont want to upgrade but i have been told that if/when the turbos go and the ceramic wheels shatter, it can cause damage to the engine, therefore wasting more money. What are the chances of this happening?
If it is advisable to change the turbos, i will bite the bullet..... I am thinking of getting HKS GT-SS and PowerFC. Have been told to get SARD 700cc inj and an upgraded fuel pump. I am thinking of getting the Bosch 044 pump and getting it mounted internally. Thoughts on this setup would be appreciated.
from basic figures, the rebuild will be about $6500, and getting all the extra parts for a turbo upgrade + fit/tune is about $7000, therefore doubling costs.
The car is an 89 GTR.... supposedly 70k. What are your thoughts? Upgrade turbos or leave it and upgrade if they fail?
again, my main concern is the possibility of damage to engine if the turbo does fail...... however having said that, if the turbos fail and i get new turbos, obviously it will be more expensive to get turbos fitted later on rather than while engine is out. Does anyone know the average price of fitment of turbos, injectors, fuel pump and powerfc and tune (labour only)?
In need of help and wise words.
Thanks in advance, Emmanuel
https://www.sau.com.au/forums/topic/63251-turbo-upgrade-or-not/
Well if your getting the engine done then unleash its full potential by also getting the turbos done, thats my opinion anyways
from what youve said, it sounds like your going to have one nice street gtr when its done :D
ive had dreams of twin GT-RS's on a GTR :wassup:
definetly do not put the old turbos on, as i know of gtrs that have had damaged motors due to the ceramic exhaust wheel delaminating and shattering making a big mess!
if you dont want to spend big $$ on those gtss's, just get your stock turbos hi flowed(steel wheels) and they will be fine for a long time.
close to 10 hrs labour is usually charged to remove+refit turbos on a gtr
I've never understood how a loose ex wheel can damage an engine. Sure there will be bits flying everywhere but how do the bits get to the other/intake side of the turbo where they can get into the engine? I've heard this a few times but don't see how it could physically happen.
Cheers
I was under the impression that the wheel ends up in the exhaust system.
I personally can't see how any piece can force it's way back up the exhaust manifold/header, back through a valve opening (perfect nanosecond timing required), then back into the cylinder where it can cause damage - all the time battling pressurised exhaust gasses. (No animosity or hostility intended here guys)
If somebody has experienced this first hand can they please exlain what damage was caused to the engine as the curiosity is killing this cat, and I assume GTSpec too.
My thoughts is that it sounds like an awful lot of money.  No doubt Racepace does excellent work, but I would consider doing some of the work yourself (if you have the ability and tools).
LW.
So many ppl on the forum throw figures around, usually mates rates or DIY costs.
For a workshop to remove the engine, strip, measure/order parts/machine/re-assemble engine, install with new gaskets throughout then re-install the engine. Then they have to put in new fluids, filters etc...well i dont think the price is too bad.
Workshops that do things by half end up costing you double:( Things like timing belts, idler bearings, water/oil pumps if required, fuel filters/imjectors, all chepa things on their own but by the time they are bought and installed they all add to the cost. If i was having an engine re-built/installed by a workshop these are the sorts of things that i would expect, and hence be paying for
Roy: I completely agree. I think you have misunderstood the point I was making. There is no doubt that Racepace does excellent work, and they charge fairly for the level of attention to detail they put in to rebuilds, but its still a lot of money. If one has the time, inclination, a little bit of mechanical knowledge and the right tools, you can save yourself a lot of money which can then be spent of further modifications.
My post was not meant to disparrage Racepace, rather to present a cost saving alternative to the thread starter given that so much of the cost is labour.
LW.
i have personally seen a gtr on which this happened and it was no doubt the ceramic exh wheel from the rear turbo that ruined the engine, the bores were marked and even the oil pump was damaged. basically when the ceramic wheel let go it smashed against the housing and maybe something to do with the cams in the gtr allowed bits to get sucked back in through a valve opening.
i did not believe it at first either but it was definetly the case, do a search and you will find a few threads about it, some people believe it some people dont. on gtsts it never happens as far as i have seen
GTSpec;
Sorry if this is simplistic but it really depends on your budget and what you want to do. You've said that ideally you don't want to upgrade the turbos; are you quite happy with the current performance and you understand the limitations of the ceramic units? On the other hand what you've had suggested to you is a fairly stout power package for a lot more money.
Clearly there are economies of scale to be had if the motor is coming to peices anyway as, if you do the turbos now, you won't have to pay the $900 or so mentioned here earlier for r and r down the track. But if you don't want to ever up the power (unlikley?) don't bother.
If you think that you may want more grunt later, a good approach may be to get a set of 2nd hand R34 N1s or rebuilt steel wheel standard turbos, about $3k ish, you can run them with the standard ecu and injectors. Add a set of Trust long dump pipes, about $1000 from Autobarn. That's $4k total, flick the boost restrictor out ($free) you should be able to have some nice power with the standard ecu. You've then achieved the economies of scale as there's nothing to be saved by doing injectors or the PFC while the car is apart. Down the track go for the PFC and inj/ pump if you need/want it.
Just my thoughts.
GTSpec
firstly let me just say that I am just finishing a FULL rebuild of my R32 (also 89 model) - I opted to upgrade the turbos, and managed to pick up a pair of N1s off an R34 for about $2k. For more details on what I have actually done have a look at ...
http://www.skylinesaustralia.com/forums/sh...ead.php?t=62632
I did a full rebuild using Forged pistons, N1 bearings, polished – balanced – linished – shot peened everything. N1 water + N1 Oil – and did some porting work up top. I also added a pair on non-turbulence dump pipes (already have front pipe and exhaust), full metal gasket kit from Tomei and replaced anything else that move and is attached to the block. These engines are 15 years old after all.
I can CONFIRM that all up including parts and labor – you are looking at a LAZY $10K, not including the turbos ('cause I already had them). I sourced parts myself, both 2nd hand, from eBay and through some contacts at Nissan – but the labor charge alone is more than half the total bill.
Brace yourself – I though I had budgeted for everything – but I still blew out by a good couple of grand
The good news is that as a result of the feed back I have received from my earlier post, I'm expecting a solid 250-280awkw with std injectors and fuel pump. My solution is a little over engineered for this much power, but it allows me to add injectors/044/bigger FMIC and PFC down the track and push up into the 300+awks with the peace of mind that the base engine will tolerate that much power.
My thoughts are – do it now if you can afford it – I would not want to pay to rebuild this thing twice.
Thats the thing... i can afford it.... money is not a problem as i am borrowing on LOC so interest rate is only ~7-8%....
I just dont want to have to rebuild an engine again while running on stockish power... if ur gonna blow an engine, at least have fun killing it hey? i didnt even trash mine around and its costing me buckets....
Ive decided to go ahead with the works.... just dunno if i should bother with the extra 600 for the greddy extension pipes over the HKS dump pipes. also, will the greddy pipes fit a HKS GT-SS??
Also, i am submitting my order to greenline, would anyone in Melbourne like parts with my order (save postage)? Call me 0403 232 338... will send tomorrow morning/late tonite so dun dilly dally
Do it once do it properly!
Forged internal's are a must - Its a reliability thing, plus it might hold its value a bit better if you goto sell it later on, as forgies are much stronger than standard cast piston's.
If money's not a problem then go for it and do the turbo's/dump's aswel :)
:P
Jun
nah dun want forged.... basically i was told that they are not ideal for daily driver as u need to warm them up to get them to the right size so they dont rattle about too much when cold
You do get a little bit of slap with forged pistons, but I would seriously reconsider given the amoun tof money you are spending. It will cost you a fortune to rip the engine down to install forgies later when you eventually find you want more power.
Maybe some with forgies could show you what they are like on startup?
LW.
.Our engine doesn't make any noises at all. so there is no waiting for the engine to warm up for the noises to stop.i've been told that if the clearances are out thats when you get pistion slap.
mate heaps of my friends cars have forged pistons and they have no noise iwould suggest you at least get the pistons done, i would get the rods as well as you don't want to have to pull the engine back out again.
Emmanuel... if your taking your can to Ben (as so many of have done)
Talk it all over with him. He has played around with most setups and knows whats hot and whats not.
If your thinking about doing turbos... tell Benno and he will reccomend the best setup based on what you want to achieve. He wont stuff you around reccomending the biggest most expensive parts if you dont need them.
Thats why im one of his 100's of happy customers.
:werd:
Ben at racepace. Said clearance on forgies have to be larger to accomodate for higher expansion rate due to difference in metal used. Going ahead without internal upgrade and getting turbo upgrade.
Most definitely will not be after more power after this... never intended on having this car for over 2 years anyway.
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
