updated again:
fixed missing image
fixed spelling mistakes
fixed grammar mistakes
added hyperlinks for each section
added section split based on content
added self tuning - fuel economy
added info on changing airflow meter
added info on powerfc tune protect
expanded info on tuning options and expected results
do they release slightly differant maps in the diff versions of the pfc/hand controller maybe ?
I was comparing my ign map to the one in the faq, and in some points (outside of the first 10x10 range) they were off by like 10 degrees. I also compared them to the ign map in the FC PRO software, they was differant as well.. ??
Mine is pfc v 5.11, and hand controller v5.01A (might be the other way around)
Wered you grab the stock map on the faq from ?
as far as i know the stock maps don't change very often
i havent at least heard they do. they were taken from my tune
but i may have done it before i did factory reset so they could be a "tuned" ign map. when i get datalogit, ill copy mt tune. reset to factory defaults then upload the defualt maps to my site and then restore my tune and upload that as well. ill expand the powerfc faq a lot when i have a working datalogit
added boost control pics, info and wiring
added djetro harness and wiring and manal
added datalogit specific extra features
added datalogit logging options
added datalogit additional functions
corrected spelling mistake of my name
corrected double up paragraph
updated again:
added airtemp sensor on unsupported car info
added powerfc inside cover photos
added reflashable powerfc info
added custom hack / diy / hand controller holder pics
added basic hand controller use
added checking sensors
added checking functions
updated install info
those 2 manuals are old as the hills and are for rx7. They are also the older powerfc so its not upto as the japanese SR20/RB25/RB26 manual.
it comes off the main wiring haress which i think is a digital output from the gearbox somehow, ill find out
It most certainlly a gearbox feed... The only other alternative is the ABS sensors but it still works on non-ABS skylines so it must be a gear box feed....
Plus the skyline has a digital sendor to the dash display....
hey guys i have a question for those in the know
because the nvct cam timing is constantly variable on the NEO rb25, can the PowerFC be mapped for this function, or how does that work?
with the r33 rb25 its either full advance or full retard no inbetween. and is activated by a simple on/off switch in the ecu at the desired rpm.
anyone know how the powerfc and rb25neo nvct perform?
is it completley mapable throughout the entire rpm band or whats the go?
no idea but if you find out let us know, will add to powerfc-faq
the vvt on the rb25 (33) isnt controlable and its automatically controller by the powerfc emulating stock ecu functionality. you can see it turn on and off under check sensor / sw but its not controllable or editable in map form
    • Yeah agreed, you can't assume that shop are they only people who ever had to work on it. It was just a guess on the mods based on how things were done back then. You can check the Air Flow Meters by the part number on their tags, they are likely either Z32 or Nismo ones (both read about the same but the Z32 one is a little larger while nismo is stock size but supports the higher airflow like a Z32). And yes, all that would get you to 450hp / 340kw To tell what is happening with the turbos, you want a photo of the tag on the core, that will say what it was made out of  (they can retain the front and rear covers to make the plumbing easier)
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is juan@bardabe.com
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
    • shit boxes, kids, and daily drivers are all welcome
