yeah what he said^^ fc tune doesnt seem to be available, and i read copilot isnt very good..But it would do, as im not doing any tuning really just need it for basic map switching..
I have searched and found numerous DLs ..but nothing that wants to work..I thought there was one on your site but if there is i cant find it..
I been searching for 4 days man..
i downloaded co pilot but dont have datalogit cable so can only load the software and look @ it
do you have the datalogit software and cable
Was going to get the HAKO cable, which i beleive would work with copilot...
EDIT there was another DL here from 2003 that i attempted but cant open HD1 file yet ..not even sure if its right..
Edited by Arthur T3
Have a power Fc now and wanted to test to see if it works.
Plugged in and initialized.
All seems good except "Engine Check Light" was on throughout the power on.
Is this a problem undiscovered by my Remapped access auto (blitz) ecu or a problem with the power fc?
Thanks
if all your doing if putting ignition on but not starting i think that's correct you should get all dash lights warning and not
Sorry, my mistake.
I meant, ignition on, reset the power fc, then turned ignition off, then back on all the way to start the car.
Then the engine warning light remained on and the others turned off.
Thanks
the engine check light (orange engine icon) comes on when a stock sensor is out of range, disconnected, fault or broken
view the sensor that is causing the issue by looking at ETC, SENSOR SW CHECK and look for a sensor with a black highlighted name
of course if you had have read the PFC FAQ on page 1 you would have known that already
on cars such as R32 and RX7 they do not have an engine check light (orange icon) and use the exhaust overtemp light instead (red CAT icon)
so if you have HR32 then its the same deal, the light is used to advise you of a stock sensor out of range, not working or mangled
  • 4 weeks later...
In electronics, fall time (pulse decay time) \scriptstyle t_f\, is the time required for the amplitude of a pulse to decrease (fall) from a specified value (usually 90 percent of the peak value exclusive of overshoot or undershoot) to another specified value (usually 10 percent of the minimum value exclusive of overshoot or undershoot). Limits on undershoot and oscillation (aka, ringing or hunting) may need to be specified when specifying fall time limits.
Paul,
Have you ever had any problems with the hand controller giving false readings or causing the car to knock
Mine got looked at today and on datalogit its fine on the map watch, Knock was fine
But on hand controller I get high readings at the same load points
Have you heard/experienced anything like this before?
Thanks
covered in the PFC FAQ
the datalogit and hand controller should not be used at the same time. this is because they share the same bus and bandwidth from the powerfc
that is, each data cycle may be missed by one and the other. so cycle 1 knock of 40 daalogit see's it, but hand controller doesnt, cycle 2 hand controller see's it and datalogti doesnt
its fine to use both to just play around etc
but if you are logging and tuning you should only use at at a time, and not both as it's a shared bus and was never designed for dual devices reading data at the same time
Thanks Paul
It seems to go a bit deeper then that though, when logging individually with both items I'm still getting more Knock on the hand controller then in datalogic. It got looked at yesterday and my tuner said it looks good, plenty of fuel and the timing is not as far as it could be. Datalogit is showing everything is fine, just when the handcontroller is in I get knock at random times. Ive got nothing plugged in at the moment and havent seen my engine light flash to indicate high knock levels since.
I'm thinking the hand controller might just be a bit funny. The main points it seems to be knocking are low revs high load (eg Foot flat to the floor in 5th gear going between 60kmh-80kmh etc)
Sorry I was a bit vague in my last post
Just let me know if you've experienced this before. Im going to do a bit more logging individually with hand controller only and datalogit only when I get the time
Thanks
is your tuner logging basic or advanced knock? should be similar but can be slightly different. how many different things is he logging at once?
also, how high are the readings your getting on the h/c?
    • The cross sectional area of a circular hole scales with the square of diameter. So a 2mm diameter hole is 4x the area of a 1mm hole. Not double. The 1.7mm hole is nearly 3x the area of a 1mm hole. You do not need restrictors at both ends of the oil supply line. If you have new, additional restrictors at the turbo end, that you did not have before, then you do not need a restrictor at the inlet end.
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
