check out the rb25 turbo upgrade dyno post (search for it) and find the most laggy looking dyno graph. copy their mods and you shold be sweet. i suspect the hks2540 will be the most laggy or gt30 with stock internals, the gt30 is suited for a midly tweaked engine
what makes u think i want lag i said all along i want 250 with torque, grunt ,response not LAG :D
  • Replies 40
quote:
"i figure i should run the more boost like 1.1bar to make it rather than go external wich requires less psi but more lag. MY REASON: so on std boost my wife wont shit herself when it come on!!!"
that says to me i want high power top end (fine) but i want lag so my wife doesnt get angry when 200rwkw spits out at 2000rpm, so therefore i want a laggy setup.
am i wrong? if so thats ok, ill chage my previous posts
but from the info you gave (limited) it said to us you want a laggy turbo thar had good top end. laggy so your wife didnt have a fit, and good top end so you could enjoy it when u kept the throttle nailed down
dude,
the HKS GT2835R is your best solution, it will give you the air-flow you need for 250rwkw with the response you require as a street car.
Garrett also offer the same spec turbo with an internal wastegate which flows the same a the HKS turbo, so financially this would be the cheaper way out.
I think you need an automatic SS commodore..... 5.7l v8.....'
Perfect soccor mum car with a bit of go.... LOL
Nah just kiding, back to the topic. HKS 2535 will see the figure you want with the responce you admire. Sard or malpassi rising rate FPR and your set.... Around 18psi i reckon and 250rwkw is possible. Assuming you have an exhaust and FMIC....
its rb25t my mistake,
but just so u know high compresion na motors arent a
bad thing with turbos u get a lot more grunt down low u
spin any turbo round 1200rpm faster u just need to tune
ur ecu properly did it twice on a vl and a skyline and i ran
26psi threw the skyline wich i didnt need wiv t3/4 combo
and 2000rpm gave full boost an massive burnout torque.
tru story  :D
thats the most rubbish filled post i've read this week.
1200rpm sooner on an N/A motor... which one?
RB30 (vl) has a lower compression to start off with in the N/A so a turbo conversion is nicer...
anyhow. Your after an RS500 said... a HKS 28XX... or basically a Garrett GT28, around the 450HP mark will get you what you want.
that was my na skyline silouette wiv factry LSD 4 skidz
RUBBISH is not what my mates said as i painted his street black with mountains of torque
dont be fololed by thinking high comp is bad!!
Forget that i ran 26psi it was becuase the t3/4 internal gate was faulty and
wouldnt open so i ran what it pumped and that was 26psi.
it made ruffly the same power/ torque with 1 bar as opposed to a low comp motor
with needs much higher boost to compensate like 20 and more.
try it then say its rubbish until then SHUT YOUR MOUTH
:D
You think with Fuel pressure regulator and a good fuel pump the stock fuel system would be able to support 250rwKw? (and I'm from perth ehhehe :headspin: )
Im about to try a 2535 but dont have injectors at the moment, hope it'll get 250kw
will have results by end of month
Stock injectors will be fine for 250rwkw, like i said, got 2 mates with gtst's who both run 2535's, make about 250rwkw, very responsive... both on stock injectors...
HeathGTST owns 'MSPEC2'... DentonR33's old car... is one
the other one is on the forums as MSPEC i think....
I don't know about the GTRS or other turbos... i just know what my friends used... and thier cars are very quick.... they both run PowerFC's tuned by RacePace.
2535 sounds like the ONE
what they worth ?
does nengun sellem?
I high flowed a standard r33 comp. Had steel wheels fitted an the BB cartridge replaced. They also changed my exhaust wheel to a different type (unknown origin).
I reached 217rwkw at 10psi on strock injectors and just a piggy back system....
(Had to drop the cat out so the exhaust could flow, as at the time i had a stock exhaust.)
Now im up to around the 250rwkw roughly when i use my race pipe. Then with the stock exhaust re connected it turn it down a little to around 200rwkw.....
thats good power from a hi flow
what boost gave u 250?
i have not cnfirmed 250rwkw with the boost turned up...
I have a list of mods as long as my arm.... 217rwkw was with just boost and a few minor mods, or common mods you may say...
I am only estimating 250rwkw at 16psi.... It would be very close to this figure tho....
Its all about the supporting mods, you could make 250rwkw from a stock setup (for about 1 second) then she would go BOOM. So its about reliable power to me... I run 200rwkw daily, for fuel reasons. Then i can turn it up with 20 minutes work....
Hi Guys, I thought that we had covered all the possible threads on turbos for RB25's, and everyone was using the search button. But then up pops another one, exactly the same
(usual) question.......so I give the same (usual) answer........
We have an R34 GTT that makes 265rwkw (355 rwhp) on a GCG ball bearing hi flow, and it makes more power EVERYWHERE than it did standard. That is pretty close to the 450 bhp that the hi flow is rated at. For a half days work, bolt on (no fabrication required) it is hard to beat. Plus it looks STANDARD, never going to have a rego inspection problem at any level. That was 2 1/2 years ago, what about the new turbos released since? Well, despite having plenty of other choices, I am using a GCG ball bearing hi flow on the Stagea.
My 20 cents worth:cheers:
tru story  :rofl:
On pump fuel? For how long?
Not even a std RB25det would last long on 26psi, if run constantly.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
