well I'm just back and it was a great day not many car cause its overcast calder looked after us really well we started from the other side and got as many runs as you needed.
times
meggala best time 14.04 @ 99.86 with a 2.1 60' time
the ice gtr ( lewahs 11.50)
ex- static 13.90 @ 104
i nark 15.05
ait 15:.5
acsplit (16.5 ) not sure
post your times here guys
https://www.sau.com.au/forums/topic/6485-calder-results/
  • Replies 89
15.04 ET @ 92.66, 60ft 2.3
15.06 ET @ 93.3, 60ft 2.399
15.09 ET @ 94.22, 60ft 2.48
15.47 ET @ 93.01, 60ft 2.68
Dont know what the last one was...
none of them with a decent launch and the last one was even worse as u can see by the time.
took a while for me even to get a run as my line wouldnt even &$&$ing start... all dressed up and nowhere to go... so once we crashed started it i left it on for the whoel 3 - 4hrs i was there... engine was hotter than hell.
the calder team pissed me off big time after all the stop starts as we were meant to be next on the last run in which i would have got another 3 runs in (after the rain) but they let all the bloody V8s go who had already done 2 bursts before the rain... so in the end i only got to do one more without trying to get a decent R/T.
meh im still happy with the result all things considering (all things being heat, car probs and shit tyres). still kind of annoyed not making it into the 14s thanks to my launches... funny thing was that on the way home i would wait for the green and actually launch properly :cool:
https://www.sau.com.au/forums/topic/6485-calder-results/#findComment-96820
^#^%$ nah i would have but i only had 3 hrs sleep the night before and had not eaten anything that whole day... plus my clock said it was 4pm lol so i thougt i better head in and call into work to tell them i wasnt coming...
meggala... i dont have the bigger turbo on it yet.... danny is going to sell me his dirt cheap when he puts his new one on it... or do u mean on urs?
all ive done so far....
POD
ECU
Stock boost.
thats it.
https://www.sau.com.au/forums/topic/6485-calder-results/#findComment-96916
Hey Guys ..
The rain was annoying!! I didn't get to meet all of you guys, but none the less I had a great time.
I didn't get the chance to run the R33, so instead I took the Rexxie! (Dark Blue one)
My times:
First Run 13.62 @ 98.82MPH, 1.904 60FT
Second Run 13.74 @ 98.00MPH, 1.939 60FT
Third Run 13.72 @ 97.75MPH, 1.913 60FT
Fourth Run 14.84 @ 98.23MPH, 2.491 60 FT (missed 2nd gear)
Best Run 13.02 @ 101MPH, 1.890 60 FT **WOOHOO**
I would have loved to have run more boost (14 psi max, at one stage I was getting 10 psi in third ) :D
How loud was the car without the exhaust ??? But I think I lost a bit of mid-range because of it, but was all fun !!!!
Hope to see you guys at the next meet.
Eric
https://www.sau.com.au/forums/topic/6485-calder-results/#findComment-96968
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
