that car looks beatiful mate.
Thank you
click below for the pics
http://www.niztek.com/forums/index.php?showtopic=661
what do you think?
To be totally honest I much prefer the Grey one you have :)
Not to keen on annodized rims, how bout you swap the seats etc from the Red one into the Grey one :aroused:
Thanks. Yep, lip is in the boot. Better pics soon.
Hope there'll be some of the engine bay :P
After that pic showing us the welding on the exhaust i'm sure i'm not the only one keen on seeing what setup it's running. Should be interesting to see what times it runs when you get it to the strip :wassup:
i still have the grey one until saturday.. but yeah its sold.. the red one should clean up real nicely..
i have to grap some standard seats for complience for the red one tho :P
i also have to find some other wheels.. the MASSIVE slicks that are on it now wont be any good for complience..
I have complied 4 cars in the past 2 weeks, all with similar issues - suspension, wheels, exhaust, guages, air filter, blow off valve etc.
In regards to the coilovers - its ok, as long as its the standard height. (thats what i have been told anyway).
I have a set of standard R33 wheels, airbox, exhaust so that parts taken care of.
As i said earlier, only issue i can see is the Sunroof.
Thiss thread is a little old but my question to you is why you would bother, given that it would have been much easier to just source and comply a stock car and modify it to your tastes (or exactly how this one looks) no offense but it looks like a massive job, dodgy/flaky paint, damaged sideskirts, and what looks to be an old supra intercooler grafted in a hurry to fit the car with little thought for airflow. add to that the amount of work you have to do.
It looks tough, big question is...is it that tough to warrant all that effort? Unless you've sourced it for real song....a real song.
Esp that given the prices of R33 these days.... and the idea of grafting a roof for compliance....
sounds like alot of good money going after the bad.
nxtime: As silver gtst so eloquently put it, lets see some more pics of that baby .. :)
He has a way with words, doesn't he? "Please" isn't in his vocabulary :)
I have more pics in my gallery.
My camera has a problem with outdoor/bright light pics, hence the poor quality.
hahaha its a nice gts,
paints looking nice.
and engine shots? ahhhem
Its a GTR... not to be mistaken with the more common GTS with 'R front grill and front bar.. :flamed:
As for the paint, I believe NXTIME just had it resprayed?
And yeah engine shots .. I agree with the engine shots :)
it never came with a wing, only a Nismo rear lip and the wing holes where (poorly) deleted. I want to be a bit different so I'm going with the sleek look :) Might fit a new lip spoiler and side skirts later.
It has some nice wheels coming and will definitely be dropped.
Nothing to see under the bonnet - it looks a bit like yours :)
ummm sarcasm?
and fully sick i know u got the idea, pffftttt rb26
go rb20 :)
ummm so yeah pics!
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
