Thanks guys yeah i was pretty wrapped , my first round win at basky! , sorry if i seemed quiet when you guys came to say hi , was a bit on the crook side , nerves weren't helping much either Haha . P .s cheers Pete , i can post on here again , yay , i was starting to miss trolling :P
  • 2 months later...
  • 3 weeks later...
  • 3 weeks later...
  • 4 weeks later...
  • 5 months later...
  • 4 weeks later...
  • 6 years later...
This place has been dead for years, everything died out around 2013 in the Tasmania forum. Lots of us still owning/driving/racing skylines, but pretty much everyone has moved to facebook groups etc. for this kind of thing (though there is no direct replacement for what this forum offered).
Pretty sad.
  • Like 1
  • 3 months later...
  • 1 year later...
Pretty sad.
Would love for it to become a thing again, although I know that's unrealistic. I really dislike facebook groups. I try to post on SAU when I have news about my build etc.
  • Like 1
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
