so does the engine still run? does it make funny sounds? I reckon you would have spun a bearing if that sort of problem happened at 8000rpm. A 33 i sold had fluctuating oil pressure after the guy bought it and it ended up being the oil pressure sender was failing so that dash was telling a different story from what was actually happening.
Errr - I didnt get to see the oil pressure on mine prior but the word is the screws loosed and the bearings farked (big End). I found out afterwards the previous owner was getting eratic oil pressure readings and was advised the gage was d!cky. Now I'm looking at a full rebuild of my 32 GTR
im sick of hearing that its loose backing plate screws that cause the oil pump problems ITS NOT, i've heard it 8 times this week!!! Its the undersized crank drive on r32 that is the cause. The drive is not wide enough it causes vibrations which wear down the internal gears of the pump(fluctuating oil pressures) and AS A RESULT cause the screws to vibrate loose. Everyone with a r32 should invest in a $240 collett from jun to save them a rebuild!!!!
im snapping one of these up , can you get the from the Jun site is there suppliers in sydney that sell the collett ?
Well, you are right, but the backing plate screws coming out is not wrong :(
I couldn't support your view more in terms of a crank collar, or even R33 crank. Its not worth losing your engine over, I was lucky with mine still got the engine...
oh the screws and backing plate do come loose no arguement but its a result from vibration casued by the small crank drive, not that they just come loose for some reason and this causes the oil pressure problems!!!
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
