heya
maybe i'm just paranoid but do any of you guys experience the back sliding a bit (oversteer?) when going 90 degrees at medium/large sized roundabouts at about 50-60km/h?
just wanted to know whether it is normal or whether the problem popped up recently (didnt really noticed it) until the heavy rain few days ago
thanks
edit: i've read that this is due to HICAS?
https://www.sau.com.au/forums/topic/65786-re-traction-and-oversteer/
They say the best control system ever is the one between your ears:)  When driving make sure the brain stays connected to the right foot:)
Thats fine, but unfortunately in my car there is a loose nut behind the wheel
LOL...well thats funny, mine comes with a tool behind the wheel.
What came first the tool or the loose nut:confused:
Well that all depends on if the nut became loose, or was loose to start with doesnt it.
Also remember that if you haven't had much rain lately and then you get a downpour that the road will be greasy and slippery until all the crap is washed away.
Gosh, I hope it rains soon, so some of the crap on this thread gets washed away. :wassup: :wassup: :wassup: :wassup:
To add some more fuel to the fire.
I find it really hard to induce oversteer on a corner at those speeds unless I really give it a hell of a lot of throttle. But it has a lot to do with suspension setup and tyres etc. Maybe your tyres are starting to get worn on the inside? I noticed a lot more oversteer when my old Toyos were getting a bit thin on the inside.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
