Black/Red (below yellow) - Antenna boost. Connect this to your antenna/amp control wire. After a bit of experimentation, this *does* in fact boost the amount of channels I could get, so a good idea connecting this up.
Hi Gordon
Dude pardon my ignorance, which wire is the antenna control wire? I have RCA plugs for the amps and a power antenna wire on the head unit?
Any info appreciated - right now the wire is just taped up inside the console :(
Mark
edit: Is there enough info in this thread to request a sticky?
I've just (today) made mounting plates for the fronts. I've also ordered a pair of 6.5's and was hoping to confirm that someone out there in SAU-land has fitted a set already. I used 12mm MDF and the plate fits behind the door np (albeit with some massaging from the jigsaw :)) but wondering about magnet clearance ref the window pane. If it makes a difference, they are Type R 2-way.
I know guys have fit 6's, just hoping the 6.5's also fit. I guess one way or the other I'll find out next week.
Mark
PS Vijay thanks for the sticky
  • 4 weeks later...
hey guys my head unit finally arrived!!! :( i was looking at the manual and looks like a farily easy install, but i was just wondering if mounting brackets would be required to screw the unit to the dash? If so would anyone know where to get them from, because it didnt come with my unit.
thanks
Anyone have a wiring diagram for the stock nissan harness at all or did you all just trial and error for the install. And the other thing is an amp bypas hard to do or would it be worthe just ripping that sucker straight outer of there instead???
The power is on a seperate plug with three wires, using a currenty tester you will work out which is acessory and which is power, the third, and left over wire is not earth, and if used so, head unit will work but fuse for rear tail lights and dash lights will blow (yes i found this out the hard way).
Moral:
Best to run a seperate earth wire.
To get it out is relatively easy, just pull the dash apard, mainly the surround of the stereo area and the two stero units are conected to each other on the same brackt and come out as a double din item. Very straight forward and plain easy to work out once you start pulling it all apart. MUCH!! easier than a R33.........but they get an easyier amplifier install.
I have blown this fuse as well for the tail lights and the dash lights but cant find the problem cos it keeps blowing as it is grounded. What did you do?
Guys,
I have recently come across this thread saying to bypass the factory amp. I have had a problem recently where i was only getting sound from one of the rear speakers although if i turn the rear wiper on they both go for a while then one stops.
I decided to bypass the amp to see if that would fix it today. What I did was connect the four speaker wires (input & output) and turned the radio on, there was nothing heard. so i removed the four jumper wires and pushed the plug back on the amp and there is still no sound. Also the radio doesn't light up any more or do anything, the only thing it appears to do is eject cds.
Anyone able to give me any pointers? are there more wires on the plug i need to jump other than the eight speaker ones?
Thanks
  • 1 month later...
  • 1 month later...
Hi Sav man,
just curious how you went with your problem, I recently installed a Apline CDA-9853 and have the same problem with radio reception. I thought the antenna cable fitted. Did you need one of these adapters and was did it fix the problem?
thanks
Do you get shitty reception if you only use 1 plug from the antenna.  Cause my car came fram japan with a "fm expander" and only one of the pins goes into it.  And with my new head unit (Alpine CDA-9826) i get crap reception.
you should not require a frequency expander, if you are using a locally sold head-unit.
Just make sure you wire up the antenna power (in the car) to 12v or the antenna/amp control of your face unit.. or you will get only very poor reception. I clearly stated this in the wiring list..
Black/Red (below yellow) - Antenna boost. Connect this to your (head unit) antenna/amp control wire. After a bit of experimentation, this *does* in fact boost the amount of channels I could get, so a good idea connecting this up.
I thought that antenna power was for the antenna's that automaticly rise.
All it does is push out 12v when the unit is turned on (or switched to radio).. this raises your aerial for instance :P Apply 12v, aerial goes up, apply 12v again, aerial goes down. Can also be used to turn on your amp in similar fashion.
But you can connect 12v to it all the time, I don't think it does any damage (mine is connected to the face unit control wire though)
  • 10 months later...
Guys,
Thanks
You most likely blow one of the ACC fuses under the drivers side dash, just replace it.
And if you dont have a diagram on your fuse lid here is a helpfull pic of mine:
:PBJ:
OK guys, I see everyone else isn't having dramas fitting their head units! I'm more than capable of all the wiring but the dilema i'm having is when my car was imported, it had only the A/C control period! No brackets, no nothing so what I want to now is- - - How has everyone mounted their headunit? Is there a generic part that can be made to fit? Is everyone custom fabricating their mounts, etc?
  • 4 weeks later...
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
