  • Replies 102
not this one :)
Yeah, I was watching most of the afternoon nursing a massive hangover in the shade (under the big grand stand) and your car looked like it was only puting out 50% if that. Any problems on the day?
Troy, did you have a skid mark at the end of the front straight? I saw you brake a lil late on one lap and left a puff of smoke, was it a close call?
Not so good watching as driving, really started getting depressed half way through the day thinking about my baby all sick at home (car that is)
Troy, did you have a skid mark at the end of the front straight? I saw you brake a lil late on one lap and left a puff of smoke, was it a close call? ...
Oops, thats two people that saw that:) Snowman told me of the first time he went flat down the straight only too find that he was too hot for turn 1...lol, well that makes two of us:)
If i didnt lock up i would have gone close ot hammering thru turn 1, but because i pinched the brake i ran a bit wide onto the grass:( So wast really that big a moment except for the fact that it was my first flying lap and i flat spotted the front left tyre leaving me with a bad front end vibration all day:(
Was the brake lock up that bad/smokey, it didnt feel too bad, but i suppose the physical evidence i left behind tells the whoel truth:)
Its got a horrible vibration now, and its really bad under brakes...lol i drove the rest of the day on it and it was ok, it wasnt down to the canvas or anything:)
I had some *ahem* temp issues and brakes going away issues...
In the morning session 4 laps was all it took to get oil to 120 (with a cooler) and water to 110...
Plus when I was on the front straight in the morning we had a *moment* coming up on that red maserati where he was braking, I was braking... and he was slowing down faster than me... I pushed the pedal harder... and got... nothing. All I saw was dollar signs coming up towards him but he turned in just in time :) I on the other hand had the GTR sideways on the far ripple strip trying to wash of speed like a crazy bastard :P
In the arvo went out for one warm up, 2 flying and one cool down and by the end of the first flying (turn 1) I had no brakes again :rofl:
How did you go with your times marcus?
I think I did something like a 1:38? Funny that last time I went out with less power and farked suspension I did 1:33... :Oops:
As I keep saying, car is capable of sub 1:30, it's the operator who isn't!
Have you upgraded your pads and used racing brake fluid?
Sounds like you have cooked the pads and boiled the oil.
Plus when I was on the front straight in the morning we had a *moment* coming up on that red maserati where he was braking, I was braking... and he was slowing down faster than me... I pushed the pedal harder... and got... nothing.  All I saw was dollar signs coming up towards him but he turned in just in time :( I on the other hand had the GTR sideways on the far ripple strip trying to wash of speed like a crazy bastard :rofl:
In the arvo went out for one warm up, 2 flying and one cool down and by the end of the first flying (turn 1) I had no brakes again :)
Did anyone take photos on the day, or have links to a website with photos?
I took a few photos but mainly just of the crashed ferrari.
Mustang sliding around the final corner.
Roy's car being towed off the track.
That's why you should buy Castrol SRF :P
Hey Al, Castrol SRF was in mine on Sunday and still cooked 'em :Oops:
I was running Endless CC-X ceramic carbon pads, and Nismo braided lines with Cusco brake cylinder stopper. Last time out at sandown was running RB74s and cooked them too, with Motul 5.1 fluid.
I believe that I have done as much as possible with the existing brake setup, and that my brake issues stem from the tiny disk so will have to look at alternatives
Why did Troy get towed off?
Yeah, Troy, why did Troy get towed off?? Didn't tell me that part did you?
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
