  • Replies 71
I will be there to watch and support Vic SAU members.
Is there a group cruising up in the morning?
Would make for a good cruise, open roads crisp cool air and no traffic at that time of the morning.
Jason.
Skyline Challenge (All RWD & 4WD Skylines except GT-R, Turbo and Non-Turbo)
Which skyline is this for???
any RWD or 4WD skyline, turbo or non
except a GT-R, they have thier own class
GT-R Challenge (R32-R34)
Ill be there, plus a cousin with his r32 and a friend with his r31
Can other people enter with any cars? Such as a ford or holden?
No the event is open to Nissan and Datsun vehicles only.
R31Nismoid is also correct regarding what is allowed in the Skyline class.
Also the event will probably go for longer than what has been advertised on the event flier. We are thinking that it will go to 6-7pm, it depends on the number of cars entered.
Early next week I'll be looking to try and get some sort of rough figure on the number of cars planning to enter the event.
Thanks guys :(
Hi guys
Put me down, Ill sail the whale down and see what she can pull :D
BTW - if ANYONE has stock skyline 16s with/without tyres and are willing to lend/sell for cheap- LET ME KNOW cos I dont have faith with the low profile 265s, wont get enuff squat!
Regards
Kim
Thanks for the interest in the event guys.
Less than two weeks to go, shaping up to be a great event.
Can potential entrants please pm me or email me (contact @ mazdarotary.net) or reply here for those who haven't already, showing their interest so that we can get a rough idea of the number of entrants in total and the number of entrants for each class.
If you are >80% sure of entering thats close enough
All I need sent to me is a one line message saying 'yes i am going to enter, and i drive a nissan skyline" for example... no need for other details (name etc ...)
Payment/Entry is on the day as well for those who were wondering.
Thanks :D
Hey, ill be there but i was just wondering what i should do about tyres?
Right now ive got Hankook K104s 265/35/18 on it, but i have my standard wheels sitting around and they have some pretty worn out Bridgestone Turanza's 225/55?/16.
Do u think if i run my 265s i will wear em out too much and would they actually be good for the day?
Thanks, Mike
:rofl:
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
