  • Replies 52
P.O.P = proof of purchase ie. receipts to show its wholesale your getting
but yeah 500 sounds good just have to organise conversion kit unless you can find a full r33 kit that does not need to be fixed ie new clutch and stuff :P
i doubt that you will find a "kit" as such, but if you source a half decent quality twin plate, that will do the job nicely...
you will need at least:
pedalbox
clutch slave/line/master
gearbox
xmember
gearstick
consol section that is from a manual.
flywheel
dust cover(behind the sump...bolts to belhousing.
that should do it.
im not aware that the computer needs mod/changing...i'd have to check up on that one.
i cant source it any cheaper or easier than you can...sadly i dont have any contacts in that area... but buy all means get a quote for the parts and ill check whether i can get it cheaper up here...
dont quote me but im pretty sure your computer may need to be changed....as it wont understand your gear changes or something, i may well be wrong. Besides ppl run na computers in turbo cars, its all about the dodgyness Aaron, you should know this :P
Unless you plan on running some more modifications eg: performance gear. You won’t need to change the auto ECU, yet.
You should be fine with the auto ECU if you’re only planning on doing turbo back exhaust, FMIC ect. I'm lead to believe (well with S13's anyway) when using the auto ecu in a manual it'll still be injecting X amount of fuel even though the clutch is in, and your changing gears, where as in the auto obviously your foot is still on the gas when the auto changes. If you can follow what I mean?
I used the auto ECU with my auto>manual S13 and didn’t have any problems if that helps.
that doesn t sound right the way i understand it, this is only true when flat changing......cos if you foot is on the clutch then your right foot is off the throttle, hence computer stops pouring fuel in...throttle position sensor takes care of that
i just checked up and computer doesnt need changing/modding....
and you need to change the instrument cluster as well.
also i can get the complete list of parts for the job, for 2800.....
look around tho im sure someone can beat that.
Ah yes, Ns.com did my wrong agian. :cheers:
Hey V8
How much do you charge to fit a oil catch tank???I live in Heritage Pak which is somewhere near you.
your talking about an oil catch can???? They are extremely easy to install if thats what your talking about. Btw I was about to pm you asking where you got the JUN front bar from and who painted and fitted it?
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
