  • Replies 172
Still out there somewhere. Usually about 5 days before they land I get a notice of arrival. I still haven't got it yet.. If I don't get any confirmation before the 10th I will look deeper into it. Such as ask the shipping company how things are going?
How good are these kits compared to all the others that i see around the traps? Im after a good quality kit that i can bolt onto my R32 GTS-t with minimal fuss and modifications but know that it will do the job and not last few a few months then give me grief.
can you match the prices offered by the guys on Nissan Silvia? The same spec ones from the same manufacturers are being sold for $180 and $150 by two different traders.
These prices are for the intercoolers. I believe in healthy competition, but what's going on in ns.com, I think it's too bizarre.
Well here is one statement he on the add.
Pressure Drop: 20PSI - 17PSI .. What the? nice pressure drop over the cooler.
same manufacturer I doubt it. What gives you that idea?
There is cheap and there is too cheap! I have cheap but I don't sell parts that will fall apart in 3 months. I would watch out buying coolers at $150... Have you read the stories about the coolers whistling. Those really cheap cooler may well be the ones and the manufacturers are trying to get rid of their stock. Maybe, I'm just speculating why they are so cheap. Or maybe they are defects.
But so far I have had 100% happiness from my customers, no faults found, no whistles and no returns. Sorry, I can't match their prices impossible!! But my assumption would be my coolers are of better quality from my feedbacks so far.
Maybe some of the guys who have received the blue kits and coolers can give some feedback.  :cheers:
Yeah that would be good to hear from others that have them???
would be good to know if the horns and temprature sensor need to be relocated and where they put them, also how the top plumbing fits between the top radiator hose and fan (R32 related).
cheers
Okay guys.. .Here's what you've been waiting for.. feedback
Started the install on a mates gti-r on Saturday and still going.
The piping is very good quality and no complaints there, all the associated brackets are in the right places and everything was provided. I was dissapointed with the clamps which kept on falling apart and were out of shape, also the piping for the gti-r went too close to the Pod (about 100mm too close) and now the pod has to be changed and/or relocated. Would of been worse with stock air box.
Anywayz.. overall the kit is good, the kit fits great, great quality piping just needs to improve on the quality of the clamps. Apart from that great kit :) (would be good if the piping didnt go directly where the air box goes though.
Thanks mate.
Greg
I have just fitted the intercooler to my car and all looks great. I have one questions thou there is a red rubber line with a T piece and I have no idea where it goes can anyone tell me as I'm no mechanic and one line I pulled off the intercooler ???
thanks
SirSkyline
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
