  • Replies 172
Still out there somewhere. Usually about 5 days before they land I get a notice of arrival. I still haven't got it yet.. If I don't get any confirmation before the 10th I will look deeper into it. Such as ask the shipping company how things are going?
How good are these kits compared to all the others that i see around the traps? Im after a good quality kit that i can bolt onto my R32 GTS-t with minimal fuss and modifications but know that it will do the job and not last few a few months then give me grief.
can you match the prices offered by the guys on Nissan Silvia? The same spec ones from the same manufacturers are being sold for $180 and $150 by two different traders.
These prices are for the intercoolers. I believe in healthy competition, but what's going on in ns.com, I think it's too bizarre.
Well here is one statement he on the add.
Pressure Drop: 20PSI - 17PSI .. What the? nice pressure drop over the cooler.
same manufacturer I doubt it. What gives you that idea?
There is cheap and there is too cheap! I have cheap but I don't sell parts that will fall apart in 3 months. I would watch out buying coolers at $150... Have you read the stories about the coolers whistling. Those really cheap cooler may well be the ones and the manufacturers are trying to get rid of their stock. Maybe, I'm just speculating why they are so cheap. Or maybe they are defects.
But so far I have had 100% happiness from my customers, no faults found, no whistles and no returns. Sorry, I can't match their prices impossible!! But my assumption would be my coolers are of better quality from my feedbacks so far.
Maybe some of the guys who have received the blue kits and coolers can give some feedback.  :cheers:
Yeah that would be good to hear from others that have them???
would be good to know if the horns and temprature sensor need to be relocated and where they put them, also how the top plumbing fits between the top radiator hose and fan (R32 related).
cheers
Okay guys.. .Here's what you've been waiting for.. feedback
Started the install on a mates gti-r on Saturday and still going.
The piping is very good quality and no complaints there, all the associated brackets are in the right places and everything was provided. I was dissapointed with the clamps which kept on falling apart and were out of shape, also the piping for the gti-r went too close to the Pod (about 100mm too close) and now the pod has to be changed and/or relocated. Would of been worse with stock air box.
Anywayz.. overall the kit is good, the kit fits great, great quality piping just needs to improve on the quality of the clamps. Apart from that great kit :) (would be good if the piping didnt go directly where the air box goes though.
Thanks mate.
Greg
I have just fitted the intercooler to my car and all looks great. I have one questions thou there is a red rubber line with a T piece and I have no idea where it goes can anyone tell me as I'm no mechanic and one line I pulled off the intercooler ???
thanks
SirSkyline
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
