I'm sure there's been a thread on this before somewhere, but I can't seem to find it.
I know that the PowerFC Pro has some sort of launch control, but is there anything else that it has over the regular PowerFC?
Is it worth paying the extra to get the Pro?
Just that I'm about to order one of the two, and the Pro is considerably more expensive by the time you factor in the cost of the hand controller.
Cheers :)
https://www.sau.com.au/forums/topic/68899-powerfc-vs-powerfc-pro/
it has two rev limiters one for when the cars wheels are not turning and one for when the car is moving.ie on the drag strip and your at the line.when you have the throttle flat you can set the limit to say 7500 for getting of the line and once your moving you could set it back up to 9000.
Hey all...
The Differences between the PRO and the Normal FC...
1) Launch Control
2) Cuts The Ignition instead of Fuel (normal FC) at The Rev Limiter
There are 2 kinds of PRO Versions...Detro one eliminates the AFM's and replaces them with MAP sensors...
The other keeps the AFM's but has the 2 extra options...
Im Running the PRO Detro version
Hope that helps...
cheers
Tony
Dude,
I know your after the bling factor of launch control.
You can always add this later. I'm fitting an external sort of device which is launch control. Can use it with stocker ecu etc. Just a sequential ignition cut I'm pretty sure.
Hey Dan
Yeh but I don't want to use the stock ecu because I'm using bigger injectors etc.
Also like the functionality of the PowerFC.
But it's all good because I have now ordered the PowerFC Pro :)
Cheers for the replies guys :)
The question is though for most ppl. How important is the ignition cut over a fuel cut as most aftermarket ecu's use a fuel cut.
Exactly. I'd like to know this also.
What I can't understand is that why have Apexi changed the cut? E.g A stocker gtr ecu uses ign cut, whereas if you change to the regular FC, it uses a fuel cut. Odd.
What are you going with simon? Still going Wolf or what? Wolf use ign or fuel cut?
James,
What I meant by that is that you can have a PowerFC, Microtec like eggy/dave, or whatever etc and add this external device and still get launch control.
Now that you've bought the FC Pro.....go and buy the software from nengun. $300-$400 del I think.
Yeah I knew what you meant but there's no point in having all this extra external crap when you can buy one unit with the lot included !
maybe, just a crazy idea in my head, but the issues with cutting fuel in hi-po engines may have lead the pro version to cut ignition instead
or a more simple and uderstandable way of explaining is - ppl who want pro must have a high grade engine, therefore better to make it cut ignition then risk engines due to lack of fuel at high revs....
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
    • You just need a different blue slip shop (preferably one you regularly use as a mechanic), and make sure the coil overs are as close as possible to standard height
    • yeah the sugar refining companies were pushing for the same in Oz originally, all fuels were going to have 10% ethanol to make them "cheaper" (noting, that the loss in l/100 might be greater than the decrease in price). I guess they won that fight in Canadia
