how much boost do you want to run on the stock turbos anyway? I run about .9 bar and the stock IC works very well. Inlet temp is pretty well under control.
What sort of inlet temps? I am running 250kW at the rears, power fc and cams on stock turbo and get inlet temps of 40 - 50 degrees :confused:
admittedly this has been more in commuting, have to see how it goes on freeway
What is average?
depends. if I sit in traffic It can quickly get up to 50degrees. then once on the move it's down to around 38. I find once it's gotten up to 50, the ic can't drop it down below around 38. but this may be in part due to the plenum and all the post IC piping being nice and hot. On the track it didn't go above around 35 (from memory). on a 26 degree day, inlet temp (that's in the plenum) of around 10 degrees above ambient is pretty good. I'm sure the plenum and post IC piping is a lot higher than 10 degrees above amb.
one other 'test' I've done is after a thrash put your hand on the inlet tank (VERY hot) but the outlet tank is very cool to touch. it actually feels cooler than ambient.
I guess the only real way to test the IC'c effectiveness is to get three temp sensors. one ambient, one ic inlet, one ic outlet. coupled with the plenum sensor you could tell:
1. how much your turbos heat the air over ambient
2. how effectice the stock cooler is at cooling that air
3. how much heat is transferred into the intake charge between the IC outlet and the throttles.
Went for a strap last night... according to the aircon unit, the ambient temperature was 16.5 degrees. While cruising at 100km/h for ~10 mins the temp on power fc wouldnt drop below 33 degrees. After a quick squirt through 2nd and 3rd gears, the ambient temp wouldnt drop below 38 degrees, and quickly went up to 40 and sat around that the whole way home.
I take it that is 20 - 25 degrees above "ambient" its time for a new cooler? (was running 17psi and made 330rwkw in the same trim as I was driving it last night) :rofl:
Danny if your got std turbos you do not need an intercooler upgrade and as for running more boost through the std turbos JUST DONT it's not worth the risk. As if they let go they can damage the engine, i thought it hog wash till a friend in perth had it happen recently ($10,000 repair bill /motor and turbos) so i would take the money your put a side for intercooler upgrade and buy new turbos, it will be the best thing your ever done.
As i'm running 530rwhp on std cooler quiet happily and the best i think you might get out of std turbo would be in the high 300s
Ps oil in the intercooler means the turbos are passing and are not far away from going bye bye , sent four sets die now(mine included)
cheers
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
