Good news, these are available again.
PMs sent to those on the waiting list, and there should be a couple of units left over anyone else who wants them
  • Replies 317
Posted Images
Hi Duncan, just bought my self a R33 GTR and am new the the forum. Any Attessa controllers left and can i get you to fit it? email me: [email protected]
  • 3 months later...
hey mate, pretty keen, had a quick read through the posts but there are too many and im in a hurry. :)
Just wanted to know if this can transfer 100% to the rear wheels?
Cheers. :sorcerer:
  • 1 month later...
Hi guys, sorry I haven't been getting notifications for this thread. :P
As mark said there are 4 ready to go atm, pm sent with details!
DWN80Y the only things you can see when its installed are an LED to show the split level and a button to adjust up or down.
zertek yes it can, but only safely in a r32.
Well...the basic theory is the same, and we originally started with something simple like the ebay ones.
But after testing they just didn't work as well which led to the ones we have now - with a program on a chip. The dial ones are pretty crude adjustments.
Check out this thread, Giant has a very quick track GTR and has tried the simple style ones and uses our one now instead....and he has got around Wakefield Park in 1.04.1..... http://www.skylinesaustralia.com/forums/in...howtopic=171761
Guest mark32
Thanks for the reply Duncan, gives me some more info to digest and research to do, I think I will get my transfer case checked out while my clutch is fitted to be confident in using one of these
I was originally going to build a torque controller from a circuit that Julian Edgar had posted on the web years ago, which i believe that the ones on ebay are based on. but thought it was too bulky for a start and also required some work with resistors and such to tune the op-amps to give the correct input-output ratio, which is not that much of a problem if your doing a one off but if you intend to sell them this can become troublesome because if you are going to tune it properly it would take some time or you would have to use trimpots which can easily come out of adjustment with vibration and the like.
When microchip released this version of their PIC chip I thought it would be perfect for such a job because all of the analogue to digital conversion (for the input) and pulse width modulation (for the output) could be done on the chip without the need for bulky add on chips to do such functions thereby keeping size to a minimum (70mm * 40mm). The all important input-output ratio of my devices is always linear by virtue of the accuracy of the PIC chip, the same cannot be said of an analogue controller that was owned by a friend that I had tested it was all over the place at the high ends of the scale, the more the voltage swing the more inaccurate (input-output ratio) it became.
My units are small enough to fit under the console and most guys with R32s usually use the in most cases redundant AM/FM radio tune buttons on the left hand side of the dash to select between different modes. This is particulary useful for guys who race them and want to change modes on the fly, just have to tap the button up or down depending whether you need more or less front bias. There are 10 modes from 1 normal factory setting to 10 which is MAX front bias these modes are all indicated by a LED to let you know what mode your in by flashing a number of times corresponding to the mode number, this will only flash when you start the car or change mode. It also has 2 other modes which are 1) 2wd mode just like pulling the fuse in the R32 (and should only really be used in a R32). 2) A mode which allows little bias to the front wheels thereby letting you spin the rears very easily (although eventually the ATTESA intervenes and pulls the fronts in.)
Although my units are more expensive than the ones on E-Bay I believe they are much more precise and are definately much smaller
  • 2 months later...
These are the least blingy thing you can do for your GTR. If you are looking for more noise, flash, HP or whatever - look elsewhere. All you get is a very nondescript switch and a little LED.
On the other hand - if you want your GTR to handle like its on rails - buy one of these. Very noticable improvement on the track and I did DECA last weekend with one in. OMG - they should ban the damm thing on a skid pad it is so good (very slick pad so I ran it at 7).
    • Hey crew, Failed my WOF cause of a lower control arm, and I've decided to hit both arms, and also the compression rods at the same time(seems they're gonna be the most likely upcoming failure points from some discussions with the lads over on the G35 reddit). I've looking at these form Z1:  https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-compression-rod-p-40716.html https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-lower-control-arm-p-40674.html I asked Z1 if they'd work as it's the same platform, just RHD vs LHD. I basically got told "Lol dunno". Specifically they aren't aware of any difference but can't guarantee fitment as they haven't done it on a 350GT. So guess I'm asking is if there is any issues with using 2005 G35 coupe suspension parts on a 2005 350GT coupe? Orginally I thought it could be something in the way of the arms that each control arm is designed to be positioned around, but that'd be an engineering nightmare for Nissan needing two different shaped control arms 😅
    • ^ This. The mode door actuator is a common failure, as is the actuator and/or the actual valve for the coolant flow control valve. I also don't know how available the mode door actuator is these days. I've been meaning to look into it and get one from wherever is possible, to keep in the shed for the rainy day when mine eventually fails. Anyway, the advice to you is to search the usual NOS part supply places, or even just go to Nissan and see what they list.
    • Have you got a pic of the actuator? My guess is that unit has failed internally and was flopping around, so the previous engineer who owned it forced it to be fully open to cold air (blocking the heater core path). As far as you can tell, is anything else wrong in the system? Likely you just need a new actuator (not sure how available they are) and then "installation is the reverse of disassembly"
    • I'm happy with the Lsailt unit that I put in, it puts full Android on the top screen so you can run whatever Nav and other Apps you want, while still existing inside the factory functionality like automatic reverse cams, audio input switching, retains factory bluetooth etc. Not cheap and the install was moderate (not simple, not hard) Yours is a V36 not V37 though right?
    • Yeap, all the NC's that I originally looked at that had a hard top were PRHT, which makes the roof line look horrible, hence why I said nope to them My only caveat for another MX5 was it needed to have a hard top, and initially I didn't think you could get a detachable hard top for the NC,  like my NB had Again, a big thanks to Matty for helping me source the detachable hard top for my little girl, they are as rare as hens teeth in Australia, and the few people who have them, keep them Also to Greg, for initially pointing me in the NC direction NC PRHT 🤢🤮 Not mine (I really should take more photos of my car), but a NC with the detachable hard top 😁 To me, the difference in how the detachable hard top roof line looks, and how it actually follows the bodies lines, like they do on NA's and NB's, is chalk and cheese compared to the bulbous looking PRHT
