  • Replies 119
Posted Images
  • 5 months later...
Mega Bump!!!!
Don't try and do this mod if you don't have the lower lip on your front skirt
The extra depth and width of the R35 GTT intercooler means it doesn't fit behind the chinless bar.
*sob*
does any one want to buy a shmick R34 GTT intercooler?
PM me.
  • 3 months later...
Got a quick question to SK and to all those who have cleaned the 34 cores.
Did you just put 50/50 mixtures of metho and kero into a bucket and just poured it into the core?
Whats the process of cleaning it?
Also how would you clean the fins?
The one im about to buy seems a little dirty.
Heres a pic? what you reckon?
The little dent wil be ok right??
Edited by siddr20
my 33 doesnt have any dents lol.. but yea all good.. dont think its gonna affect anything!!!
how about cleaning it?
I spoke to two of my friends n both mention not to bother cleaning the inside, as it will flush itself out.. and the oil will still come back.. ???
but i might just use water and flush something out?
or metho??
Metho and kero in a 50/50 mix is the go. Make up about half a litre, then pour in a bit at a time, give it a good shake so it can get to all areas inside the core, and then pour it out. Keep repeating the process until the mixture comes out as clean as it went in, then you'll know that most of the oil will have been washed out from inside the core.
There's no need to rinse it out with water - the metho/kero mix will dry itself out, being alcohol.
  • 2 months later...
This has been a great read!
I was lucky enough to pick up an R34 GTT Intercooler for $70NZD :P Picked it up tonight.
Some of this R&R (WTF?) and timing stuff gives me a headache tho ;) Im so new to the turbo scene that i really dont know alot about it.
Currently i have a 98 R33, with 49,000km, HKS Silent Power cat-back exhaust, A'PEXi intake and earthed stock solenoid. So essentially still running stock boost. I have a de-cat pipe on its way (yay for no cat regs (YET!) in NZ ;) ))
seeing as i know squat, am i going to have any pinging issues or anything i should be doing to aid with these mods? Will be getting a split dump/front pipe very soon too.
Noticed the bumper and rear end in general is getting rather fuel-dirty, and i know that the 33's tend to run rich when you free them up (is this what R&R is?) So i guess after the R34 Intercooler, some sort of fuel management might be needed.
Has new stock gapped copper plugs too.
Edited by gotRICE?
  • 1 month later...
so can someone plz confirm for me....(honestly i didnt read the whole 5 pages of thread)
Sk can ya help me or anyone who knows the answer below.....
a R34GTT Side mount will fit direct onto a S2 r33 to replace the stocko side mount with no modification?
(only 'mod' is the 'air guide shield')
plz let me know asap cos im really keen to do this if it works...
Cheers
Matt
Cheers
Matt
grab a 34 gtt shroud, saw a pair for sale in the classifieds...
Slightly more responsive, not seeing a rise in boost at the plenum tho
Cheers
Matt
Confirm x2.
Just make sure the inner guard bolt/clips are tight. Its lower than the R33 so its tight.
they fit up no probs.
one prob, I suppose, may be the bracket... I feel I bent mine a little to get to fit? cant remember
and they sit low seeing they are 20% larger as such, dayz kit covers that but stock front bar may not
I still use the stock holes for the air feed, just a return feed fmic off ebay now (apexi, for 180sx; I did have the r34 cooler for half a year tho), fits in the stock front airdam perfectly
  • 3 months later...
having trouble tracing the final progress of Sydneykid's 200awkw endeavours; does anybody know where this finished up? And is 180awkw possible with the standard series 2/R34 sidemount cooler? Did SK go a fmic?
    • Stock RB fuel pressure is near enough 43.5 psi, so the latency in that table at 31.6 will be close. You can see that 7 or 8 psi equates to about 0.4µs extra latency. So if you wanted to interpolate between the 31.6 and 39.9 psi values you could say you're going up about 2 psi out of those 8, so add about 0.1µs, which is barely worth talking about and is quite possibly wrong because ideally you would fix the latency while running at the appropriate conditions on the dyno, with a wideband sniffing its butt.
    • The pressure, is what you set the fuel pressure to. If you have the factory fuel reg, you'll need to find the factory spec. I don't know it off the top of my head, but someone else might.
    • For others, what GTSBoy states here should be paid attention. Why? Well lots of people play with different engines, and they LOVE to change things like remove AC, or steering pumps etc, and it lends to them needing to move the tensioner too. You want your tensioner, particularly those that are sprung or hydraulically tensioned, to be the first thing after the harmonic balancer, or technically the "last" pulley in the chain. By saying last pulley, I mean look at the direction the crank spins when the engine is running, follow the belt from where the crank is pulling the belt FROM, and keep following that until you're between the last pulley/accessory on the belt and about to reach the crank again, this is the spot where you put the tensioner. This is the area that will always end up with slack. This is worked out exactly the same way for chains too, as the physics is the same for them. The crank pulley is where all the force to drag the belt around comes from. You will never ever get rid of the slack that appears, especially under load. The tensioners job is to keep the belt loose enough when stationary that there shouldn't be out of sync movement in slow movement, and then be tight enough when running, that the belt can't jump off any gear and get damaged. Too tight, bad things happen, too loose, bad things happen. Have a tensioner (mainly sprung/hydraulic one) in the wrong spot, it can't actually do anything about keeping the tension.
    • It was gonna take much longer for the 440cc so I'd thought I'd risk it with the 550cc. They finally arrived and I couldn't wait any longer (I could but I was quite excited after 2 months) and installed them myself. Removed the old injectors, inserted the new and connected everything up. Before starting the car, I tuned the injector size from the factory 270cc to 550cc using Nistune.   This did some of the calculations automatically which catered for the TIM. The latency however did not seem to change. Deatschwerks have the tuning data available for each injector online, and I had a look at it. It has a table which relates to latency according to pressure and voltage (see below image). Nistune requires the 14v value, but I am unsure of which pressure value to look at (my lack of knowledge and experience have something to do with this). The highlighted value is close to my current latency which is 760µs. It is for 14v which makes sense, and the pressure is 31.6 Psi.   I still gave the car a test drive to see how it goes, and honestly it has never felt so powerful before (and some people say the RB20DE is very weak?). I really enjoyed the drive. Side note; The injectors are quite noisy, which someone mentioned before. This does not really bother me however. I will still ask my mechanic to have a look at it and perhaps ask a tuner to fine tune it if they have the knowledge.
    • Also true. But imagine not wanting new injectors? Imagine wanting to use 30 year old injectors?
