  • Replies 48
  • 3 weeks later...
It's not that I aren't keen, it's more that everyone dreams of the mighty 25/30 rb and it never ends up happening. To do it right costs more than any other RB25 or 30 build. The end user, ie the one paying the bill needs to weigh upi the costs and decide if it's what they want.
As Steve says, you can get low cost RB rods these days, and there are people stocking pistons specifically for this purpose now, so at least that kind of custom expense is eliminated.
https://www.sau.com.au/forums/topic/70086-rb2530/page/2/#findComment-1335675
masTers, 15k is a safe minimum and more is not unheard of.
IMACUL8, as I mentioned in the other thread, I will talk about it but not now. Too calm at the moment. Will have to wait till I get a bit boozy and can just let it flow.
No more pms please ppl ;) I've been inundated by ppl who want to know about ants l33t engine bulding skillz - well you'll all have to wait! (at least till we confirm what we suspect. don't want to be unfair)
https://www.sau.com.au/forums/topic/70086-rb2530/page/2/#findComment-1345804
Matt smiths RB30DET is a very basic motor with very small cams etc yet so strong and running 11.6 while having to feather the throttle down the track to try get traction was proof to me how good the 30 combo can be.
This motor gets a real beating and seems to take it with no effort so i now think the RB30DET horror storys are just that.
This motor was built by Wheelspins Steve lee for PER4MANZ running a single ITS turbo.Matts only running modest tune as the gearbox cant cope and the car was build for drifting so who knows its full potential.
Costs of these are much the same as any other RB tho the rods are cheaper than whats avalible for 25/26s and the cam belts easy now and all the normal RB extras like oil pumps etc are the same.In a GTR remember that you have the costs of the sump addaptor but even thats cheap on SAU now.
https://www.sau.com.au/forums/topic/70086-rb2530/page/2/#findComment-1349391
stock internals 8.3:1 compression
picked up a rb30 short motor $150
R32 RB25DE head $750
Vl Head Gasket + rings + timing belt $250
Bearings where good
Already had a wolf3dv4
used top half of plemum of rb20
If u can do it urself its cheap
How much power is it making and for how long have you been using it?
I've given up on this path - couldn't justify the budget required. Have gone the path of the Neo instead. :)
https://www.sau.com.au/forums/topic/70086-rb2530/page/2/#findComment-1355171
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
