are the water lines included ... or are they extra?
:) depends how many beers I've had :)
What are the flow rates of the said kidney?
Well, this is quite an interesting question. I've tried to find the theoretically amount of liquid that can be cleansed via said left kidney in a 24 hour period, and it ranges somewhere between about 2 and 24 beers before extreme discomfort :dump:
Do you know if its a good upgrade, & will it fit a 1980model?
true the 1976 model is starting to show its age by now, although it may be adapted to a 1980 model, but may need some extra trimmings around the housing at this point.
Can I make an offer on your right knee cap. I'm good for the cash.
I'm not interested in the Kidney as I have a witness that saw you racing another Kidney and I don't want it if it's been thrashed. Plus you blew some smoke last time I saw you take off.
So how about it...knee cap?
this is all too funny.. but I think i'm going to be withdrawing my kidney is from sale after a hard saturday night after it suffered premature and unexpected failure.. and I'm off to spain guys.. seeya!!
:D
ahhh..dorridorri comment in there too - good work!
are you registered with ebay square trade? I am!
Here's how we'll work this out... I'll send you a cheque to cover the costs of said kidney plus additional shipping, as i am currently in mexico. I will trust you to pass on the excess cash to the shipping company :)
If you have any problems feel free to contact me via email only, this deal will be completely safe as i'm a nice guy ... and registered with ebay square trade
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
