morning all,
my little bro has recently got his licence in a manual and when i was drivin with him the other day he informed me that i shouldnt be rolling or "coasting" as he said in neutral down hills. Apparently his driving instructor has told him that it isnt just bad when gettin tested but also it is just plain bad for the gearbox..... is this just something to make him not do it or can it actually do something to the gearbox.... i cant see how it could. ???????
.....Cheers.....
https://www.sau.com.au/forums/topic/70825-will-this-kill-gearbox/
why do you roll in neutral down hills? only time i can think that you'd do that is to come to a stop, which some people say is bad, but brake pads are cheaper than a clutch :rofl:
It definatly won't harm your gearbox coasting - how can it? there is just no gear engaged.
It's a bad habit at best stupid thing at worst. This is because if you need to move you're not in gear, also if someone pulls out on you or something it's one more thing you have to think about.
I even think coasting to lights is a bad idea but I've done it when lazy but I would recommend learners/those unfamiliar with driving not to do it... as ferni said though those who know what they're doing and wish to be changing pads instead of clutches go for your life :rofl:
And no it won't hurt the gearbox as others have already said.
Actually, all good points above but when I was instructing new drivers in Cars, 4WD's and Trucks the primary issue is if the engine stalls.
First, the power steering will continue to run even if the engine is not fuelled or sparked. Ever try to turn the wheel in a modern car without power steer? It can literally drag you off the road.
Second, the brake booster is vacuum assisted so likewise your brakes will work much less powerfully, but will still be powerful if the throttle is closed and the engine turning.
Finally on a truck the engine brake can still operate even is something else has failed and clutching would cause stalling.
Bottom line, keep it in gear and the clutch out.
Yeah i agree with all thats said here, its not bad for the car...
Geoff: how does putting it in neutral cause the car to stall? I understand if it did stall that would be very dangerous - but i've never had a car stall in neutral as far as i can remember.
Andrew, it's a just in case issue, and Skylines can have that stalling saga.
I've had a few vehicles with stalling problems so I see the merit. 2 were trucks that weren't my regular drives and it scared the crap outta me.
coasting in netural isnt bad, and if you are too dumb/slow to put it back into gear and slow down when i car pulls out in front of you, you shouldnt be driving in the first place.....
steve
there are other things to consider than just cars like kids and pets runnin across the road and as fast as you think you can whack it in gear sometimes its not fast enough.
i was always taught to leave the car in gear simply for that reason.
why do you roll in neutral down hills? only time i can think that you'd do that is to come to a stop, which some people say is bad, but brake pads are cheaper than a clutch :P
that is basically what i was talking about. coming to a stop at lights and intersections. Where im from, there are a few hills leading to intersections and i usually throw it into neutral. i knew it was bad for autos...thats why i was wondering. But point taken about the safety issues. cheers.
If you're out in the sticks and you're going down a huge hill then there's no reason to keep the car in gear. I coast in neutral all the time as what's the point of accelerating down a hill when you're braking at the same time? You're speeding and slowing the car at the same time and I see that as inefficient.
But tha's jus me :P
Rolling down a hill in neutral will actually increase your fuel bill.
The skylines and all new cars have a fuel cut when you are off the throttle and decelerating. This saves fuel.
Idling down a hill will only use more fuel.
Try this for an experimentation.
Use your gears to slow you down always, only use your brakes when your doing around 20km/h.
This means you will have to read traffic and drive a little cruiser than normal.
Watch how many kays you get out of a tank, I think it will suprise you.
I think this is one reason why some only get under 400km's to a tank where others get mid to high 400's.
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
