Hey Guys,
I am curious.
You know how the car stands you buy to sit the car onto once you have it jacked up? Well are they bad to use on the side of the car? I ask, cause they are made for axels arent they? Not the side of the car?
If you look at the jack in the car, it has a more of a box shape, with a small opening to fit in the correct spot on the car. On the car itself, it has a built up solid part for it to go on.
The car stands don't have this. Will this bend the bit under the car?
Same goes for using a floor jack in those spots.
Assuming that it will cause damage, where should you put the stands? Or can you buy stands that have the correct 'fitting'
Do you understand what I mean?
https://www.sau.com.au/forums/topic/71165-using-car-stands/
For front, I would really use anything other than the bottom radiator support for jack stands.
When jacking, I tend to use the tow points, as they are welded to the end of the chasis rails and come down nice and low, and obviously are designed for a weight bearing load.
https://www.sau.com.au/forums/topic/71165-using-car-stands/#findComment-1313922
yeah good question.
Some things to avoid when jacking and using stands.....dont use the sills where the standard jack goes, and don't use the chassis rails. Unless you have a nice wide piece of wood or similar to spread the load out....otherwise you will bend it. Don't use the sump.
The best places are the front and rear subframes, or the diff at the rear.
https://www.sau.com.au/forums/topic/71165-using-car-stands/#findComment-1313969
  • 2 months later...
Yeah I just bent my chassis rail a bit doign a preliminary jack .. :)
Sorry to sound like a newb, but what are the orange things that come in the toolkit (I have a GTR but i imagine it would be the same for all r32s).. are these used for spreading the load for the jack?
I have to jack up the rear of my car (just one side) and the diagram in the instruction manual doesnt really show anything, and the instructions dont specifically say where to jack it?
https://www.sau.com.au/forums/topic/71165-using-car-stands/#findComment-1462065
Just in front of the rear wheel theres a peice of steel that rounds out with a bolt in the center. From what I can see its the most logical thing for the jack to slide into given the shape of the top of the jack from the toolbox in the back. It seems like the right spot but i'm not sure. And my gf has my digicam! :)
But I get it back tmrw :D
https://www.sau.com.au/forums/topic/71165-using-car-stands/#findComment-1462160
Could someone chuck up some photos or something cause i'm really struggling to find a good place to jack up my R32 :P. I was just about to use the chassis rails but I don't really like the idea of bending them :P. If someone could explain where the hell the "The best places are the front and rear subframes, or the diff at the rear." are i'll take some photos.
https://www.sau.com.au/forums/topic/71165-using-car-stands/#findComment-1468683
  • 3 weeks later...
Good question, coz im just about to buy stands. No way im paying mechanics to change oil. So what do people do? make there own adaptor out of metal or wood like benm said. Then use the sill, that sounds the go. Do you fix it to the stand or let the weight of the car hold it in place?
https://www.sau.com.au/forums/topic/71165-using-car-stands/#findComment-1503023
  • 4 months later...
According to the R33 manual, you are supposed to support the front and rear of the car on the outside rail. Right next to the skirts. Mechanics use rubber blocks for various cars, and the Skylines have a seam which sticks out a little (the part you bent?) For Skylines, the rubber block must have a slit in it for this seam.
To jack the car, you really shouldn't go off anything other than the cross-member or gearbox mount. (would be pretty hard to get the gearbox mount that far back!) The sump sounds like a BAD idea to me.
Hope that helps!
https://www.sau.com.au/forums/topic/71165-using-car-stands/#findComment-1789379
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
