The RS-R run slightly wide as well. Go the same size you did on those.
Will see how i go... A few supply issues with them as they are discontinued!
I didn't notice my RS3's to be any wider than the dunlops that were on the evo.. The federals have a massive casing too so you shouldn't have a drama with the hankooks fitting under your car Matt :yes:
Good because there are no more 265s available so 275 it is lol
Well you will be at 1 with traction now son :D
Oh i dont know about that :whistling:
But the car is booked in with Road2Race to get it setup right :yes:
I've had kumho ku36 in 265/35/18 all around on my gtr for about a year and half now
In the beginning they were good, now for past year they are just getting harder and harder and the tyre noise is unbearable, drives me crazy !
Rears have about 20-30% left fronts about 40%
I'm taking them off and going for nitto INVO's in 265 have herd nothing but good things about them
The invo's are a great tyre Michael had em on my old 33 they are literally silent on the road and I found them really good in the wet too! ;)
When are these RS3's going on Matty? :)
2 are on, 2 are for sale...
Road test this weekend :banana:
Got some 235 Z222s on the front and some 255 Fed RSR on the back
Will let you know how they go at racewars :) ( if my cars ready )
You are all backwards :P
I have 255RSR up the front and 275 Z222 down the back ;)
Was going to get Rsr all around,
Could get front z222 cheaper than rsr, so i got them.
I do track work, so tighter tyres on front could be better
Yeah i will be doing plenty of track work and know the RSR front wont be up to the task ;)
I have just scored a set of 34GTR rims and will start researching proper tyres and will keep the current combo as my street/thrasher set!
Make sure you report back with thoughts on the Z222 ;)
This is 275 grip on the rear :P
1265536_700169503374776_1002666072_o_zps
I have 245/40s on my 34 GTR runs (on a 33 gtst s2) and they seem OK. Looking for a replacement and thinking RE050A or Pirelli?? Or the Invo's you guys all seem to rate. My RE01s are worn and the road noise is terrible, looking for a grippy but quiet set.
I just scored a set of 34GTR rims and will run Hankook z221 all round in 265/35/18... Not ideal for street though! Ill run the XT7 setup for street!
The RSR's kept me on the runway at 240km/h at racewars, thats a pass for me :)
Will let you know how they go on the track.
Pressures make the biggest difference with the RSR!
Ill have mine on the track on the 25th too :yes:
  • 3 weeks later...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
