  • Replies 40
hmm depends what you want to do? Mates got r31 and i find them to be a solid car that doesnt brake :(
To give you an idea what you can do with it;
Turbo your rb30 (rb30et)
Put in an rb20 or rb25 engine :(
but if you add a turbo it would be best to upgrade your stock brakes to something like r33 gts-t brakes, also add an lsd would help get the power down better
https://www.sau.com.au/forums/topic/73166-help/#findComment-1344151
go the 31!
definately move towards a brake upgrade even if its just good pads fluid but if your going to up their power go caliper rotor swap
pm DSTURBD if you need eny parts he farms 31s down south in the bunno area and should be able to supply anythign you need cheap
but yeah a very solid safe car to be hit in...... lol
https://www.sau.com.au/forums/topic/73166-help/#findComment-1344287
become and SAU member, then go down to all the sponsors and ask them to go to town on it :(
I am a SAU member :wassup:
Hey at least i know I'M going to be safe if i get rammed into or fly off the road... Hehe
Ok so brakes and a turbo good thing to start off with then ey,
Great Help guys cheers :(
Splatt
(keep it coming)
https://www.sau.com.au/forums/topic/73166-help/#findComment-1344509
I dont think putting a turbo on it is as easy as it sounds, you are going to spend twice the value of the car by doing that, would be better off buying something with turbo already in it.
oh and for all the ppl using the other view.
https://www.sau.com.au/forums/topic/73166-help/#findComment-1344759
Good to see another female wanting to improve her car. :(
I agree with gun32, if thats the way you want to go. Turbo = bigger brakes needed.
Personally, I think you should just keep that car for a while & get used to driving for a start, save up money & then buy a newer car already with a turbo in it after a year or two, if power is what you want.
By putting a lot of time & money into converting a car you might in the end decide to change up after a while, so just think ahead about what you want to do, and from there it is easy. If you are going to do it, you would probably be spending as much as you would by getting something similar, like a 180sx.
Good luck, keep us updated. :(
https://www.sau.com.au/forums/topic/73166-help/#findComment-1345351
man i should change my name to a girls name then post a photo of some hot chick as my aviator then ill get help straight away........ look how many replys this chick gets in 1 day to her thread
lol
You saying im hot? :cooldance
HAHA
https://www.sau.com.au/forums/topic/73166-help/#findComment-1345415
aviator?
As Driver asked, looks or performance is the question!
Let me help u pimp ur ride!  You do the spending though :(
Hmm well with what everyone is saying maybe i should go with looks for now till i do get used to driving around a bit more,
I'll have to see what happens.
Gettin a half cut sounded alright but might look into that a bit further and see how we go..
Thanx guys
Nat:cooldance
https://www.sau.com.au/forums/topic/73166-help/#findComment-1345458
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
