311 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 148
well ye, i want one with low k's and if u get a late model supra there r some minor changes with aesthetics. Also knowing u have a 97 RZ instead of a 93 is a good feeling.
the later models also have bigger brakes I think.. Supra for the win. Around the same weight as the skyline, with MUCH better tuning potential.
Pfft Supra's starting to look dated.. Who cares? 34's will look dated in 3 years. And probably hold their value worse than the Supra.
ye they did come with the larger brakes though it was only the RZ's (Late model RZ-S still had standard 2 pot brakes) RZ's also came with recaro steats, REAS suspension and some other minor things
my N/A supra goes just has hard as my GT-T, supras are more suited as a weekend car as the r34 a better choice as a daily driven car.
i also have a NA supra (see my gallery) and they will beat most NA cars along with some turbo's and V8's
I hate you so much.
"Hey guys, should I buy an R34 GTT or a Supra RZ? Also, I've discovered my girlfriend is bi and wants to bring her model friends over every night for a threesome, foursome and even fivesomes, my wallet is too small for $100 notes, and I can't seem to find underpants capable of holding my collosal man tackle in."
And here I am sitting looking forlornly at both, thinking to myself........ someday it will be mine, and here you go, having to choose between two of the most desirable cars in the market.
I am jack's burning jealousy.
After all that, I'd still pick the skyline. They're both awesome cars, but I just like the lines and 'feel' of the skyline over the supra, but hey, that's just me.
Just realised this is an old thread. Oh well, have to get my count up anyway.
Stuff that! GTR with a 2jz-gte would be my ultimate ride!
hell yeah. has anyone attempted this yet/thought about it? but for the sake of this pole, supra any day of the week. bolt on big turbo, add lots of fuel and tune it properly, easiest 600hp+ ur ever gonna see. where is the common 'limit' of GT-R internals? i know the pole is for GT-t's, but im feeling generous here, so i'll let the skyline boys use the GT-R for this one
SHUTUPPPPPPPPPPPPPPPPPP......id pick a 34 NE day.....(i had the choice between the 2 and i went for the 34gtt)
my only reason......was because compared to r34s....there are to many supras on the road....same reason i didnt get a 33 GTR even though its a GTR its still a 33 (gets rdy for the flames) LOL
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
