hey guys this stuff has been sitting hesr since i sold my car and i dont need it anymore.
RB20DET Actuator. provides more boost than the rb25 actuator. $30
Cefiro intercooler standard. good condition, once again came off when i upgraded the cooler. $50
cheap boost controller bleed valve $20 used for a week or so.
6 Injectors from seres 2 rb20det. came outof my car when i upgraded the injectors they work fine just need new pintle caps. 270CC. about 72,000 ks on em. $50
RB20 AFM mesh removed only removed as i upgraded to a Z32$50
1. Series 2 rb25 turbo compressor cover and compressor wheel.
2. TO4E V trim wheel i bought brand new to fit to an rb20/25 turb
3. metal exhaust gasket for rb20, 25 turbo dump
4. Silicon turbo hose 3" inches
$100 for all the turbo bits!!!
1, take off your rb turbo and take your turbo, this compressor wheel and housing to a turbo place and say "machine this wheel and housing to fit this turbo.
GO HERE FOR TURBO INFORMATION
all prices are negotiable!!! and can be picked up from inner west sydney, or i will post to you
sonuds ok but you are in wa!!! postage would be like $10 and i would want $15 for it so you could prob buy one locally for that much and i would rather sell it to whoever buys the compressor as they will prob need a new gasket too.
but if after a day or so no one wants all the bits together its all yours :)
i will pm you in a couple o days
cheers!
is the bleed valve still for sale?
OK i have now ansered 46 private messagea about the turbo stuff. and no one has bought it yet.
Its not like i am asking for a lot of money here the compressor wheel alone is worth $150.
and i am throwing in another compressor, a gasket, a compressor housing and some silicone tube!!!!!!!!!
somebody buy it or i will throw it in the bin.
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
