Most people know that I always look for and generally find a reason for freak results. I believe there is always an explanation/reason. I sit and study the data logs from the race cars for hours looking for reasons, hints, symptoms etc anything that will give us a competitive edge. So, sorry if the following appears a little harsh but it is based on what I see.
Hi Paul, I agree with Cubes, your power flattens off over 5,250 rpm, you should be up around 200 rwkw at 6,300 rpm based on the lower part of the curve. A properly tuned and set up RB25 with your mods makes it max power around 6,250 rpm and yours looses 15 rwkw instead of increasing power in the last 1,000 rpm. It is good up to that point, as good if not better than most. That's why it feels fast.
My guess is you have a restriction that is limiting the flow over 30 lbs per minute of inlet airflow. Or more likely, an exhaust restriction that is limiting the out flow. My first suggestion would be to take a critical look at your dump, engine pipe, cat and exhaust. Maybe even try a dyno run with it disconnected at the front of the cat. That will tell you where to start. At the same time take a close look at your boost curve, particularly what is happening under and over 5,000 rpm. I try to take a boost pressure reading at the turbo oulet and compare that with what I see at the plenum. If there is more than 1 psi difference between above and below ~5,000 rpm then you have an inlet restriction. Have a critical look at your filter, intercooler and inlet pipework.
When looking for an issue like this, I just do one power run and log everything that I can. Costs very little, if you do it at a club day $50 or so. Then it is time to look at the tuning, what are the A/F ratios like over 5,000 rpm? What are the ignition timing settings over 5,000 rpm? Have a look at the maps on the Commander and just do a simple comparison while refering to the dyno graphs. The answer is there, I guarantee it.
Hope that made sense:cheers:
ok stupid questions when you get a front and dump pipe done and fitted they change the pipe that has the oxygen sensor on it don't they? looking at my car the pipe that has the oxygen sensor on it appers stock (its probably 20cms long??) - this is the dump pipe yeah? then if so ive still got the stock dump pipe. 20cms down i can see a new pipe which looks to be 3" then it goes under the car. i remember seeing under the car that i saw the new pipes but never checked the dump pipe area
  • Replies 51
The stock "dump pipe" - or one off the turbo has the O2 sensor.. unless you have an aftermarket one (not all aftermarket are one piece). Usually the factory ones are cast and have a browny/reddy colour by now.
If your stock dump pipe is still factory, I would say thats probably an obvious restriction..
Paul,
Do a full power and Map trace run through say second gear. Take note of the load points it uses.
Let me know. :)
Edit: Just in case you don't know.
On the hand controller go in to Monitor, Maptrace then press the right arrow key. This will mark every load point you use.
I'm comparing the map to a stock map with comments to show you where the differences are and by how much.
I'll post the map tomorrow.
*** not meaning to make examples of people or anything. i took 4 other non powerfc or aftermarket ecu dyno runs from the rb25det dyno thread and put them below ***
heres my latest dyno. after powerfc knocking fix.
my peak power goes between 130km/h to 180km/h redline of 4th.
my max power looks to be much more than the safc/stock ecu combo's below.
**** it i dont my max power is lower. my average power is much better than the non powerfc configurations (4 below).
http://members.dodo.com.au/paul/pics/dyno/172rwkw.jpg
http://www.skylinesaustralia.com/forums/at...achmentid=25688
203rwkw
mods
3" exhaust
pod filter
10psi boost
safcII
FMIC
BP Ultimate 98
stock standard turbo
http://www.skylinesaustralia.com/forums/at...achmentid=25736
185.5kW 93 series 1
Engine management - Stock ECU
Boost ran - 0.9 Bar
Turbo - Stock
Fuel used - Optimax
Stock all other internals.
Apexi AVCR
Hybrid Front Mount
3" Exhuast from dump pipe back
Pod Filter
HKS SSQ BOV
http://www.skylinesaustralia.com/forums/at...achmentid=25752
1994 R33 GTS25t
Avcr - 0.8bar
Full zorst
Trust IC
Standard Turbo
Standard Ecu - no tuning or piggybacks
Automatic gearbox
180.3 Rwkw
http://www.skylinesaustralia.com/forums/at...achmentid=25791
1995 gts-t
Stock turbo
pfc
gtr fuel pump
adj fuel press reg
3'' catback exhaust
ebc
Pod filter+partion
Small Hks front mount
Slipping stock clutch,leak in header/exhaust gasket.Cant remember what boost it ran...
12:1 afr's
182.0rwkw
http://www.skylinesaustralia.com/forums/at...achmentid=26012
Iv got 172rwkw S1 R33 Auto
Stock turbo
Stock cooler
10 psi
Cat back zorst
Pod
Auto Tranny
ok the top dyno is my car, my hp jumped heaps when we fitted the SAFCII,
I have to agree with nickr33 about the nasty holes in the power curve and yes it was time for a powerfc upgrade...
the mid range power you talk of... well my car on the road had little mide range and little power until above 5000rpm then the power kicked in pretty hard
by the way i have had my car on 2 different dyno with same figures
NOW.. like i said before it is time for a ecu upgrade.. i now have a power fc and gezzz it made a huge difference... not only in max power 290hp (216kw) but in drivability.... meaning more power midrange and accels heaps better
not sure if ive added any heapfull info but .....
im gonna jump up and agree, my rb25 that manages 0 to 100 under 5 seconds only gets 170rwkw only 2 seperate dynos'. ice performance checked it out and its fine. making the normal amount of power. powerfc, [email protected], cooler, zorst, dump/front/cat 3" so the usual mods. however ive seen stacks of cars with just safc or remap hit 195 all the time. so either the dyno's are on crack or shootout mode is off the scale or my tune is shit. or something is wrong with my engine. now im not trying to be the "winge winge rb25" guy sure my power less so be it, there must be a reason surely.
now i know that an rb25 with safc (or remap) and exchaust cooler may make 195rwkw at max but im sure my 170rwkw max top figure should out acceralate the safc tune as the powerfc tune is more aggressive, well theoritcally speaking it should be? i guess the only resolution is a dyno day and do change any of the dyno settings for the day. the freak "ecu" thoeory has been thrown around a bit and i remember sk shooting it down a few times, theres always something that is the reason for the "freak" power output. maybe servicing history or some crap has made the engine stronger. my rb25 is on 120,000 odd so i wouldnt call it "old old" but it certainly isn't new.
Power in sig dynoed at Ice performance. Car has 79000 on the clock dont know if its genuine K's but is in top condition
I just had my Auto R32 tuned. It made 168rwkw.
Mods are: pod, 3" full exhaust, RB25 turbo and FMIC and 14 psi with GFB bleed valve.
FMIC alone made 14rwkw difference on stock boost. (144rwkw on 10psi)
At the same time there was another R32 manual, with RB25 conversion with pod, exhaust and FMIC and it made 160rwkw on stock boost (7psi)
How about this theory Roy.
I'm putting it down to the way in which the available airflow gets through th system to the engine.
In the past if you looked under the bonnet of a modified street car, it would have all the good names on it but no thought about how the airflow gets around. Nowadays with the same good names of harware, guys are streamlining the airflow path.
This makes less heat, less restriction and so on to develope more horsepower.
May have a little to do with the tunning ability of the guy as well
Turbine
We have picked up quite a bit of power with Optimax and Ultimate now being more readily available and also safe to tune to. Plus we are tuning tighter around the A/F ratios and we know we can rely on the knock sensors, so the ignition timing optimisation is more confident. We are using faster/more accurate lambda sensors so we have reduced the allowances.
As for the cars themselves, well I will pick up on one point, heat shielding and ambient air feeds. We would hardly ever see a car with a decent heat shield and air feed, open pods sucking in hot air were the common sight. Not so much now, but still too much for my taste.
Plus I reckon I have picked up 10 rwkw from reading the forums (this one in particular) and implementing the good ideas of others. Don't underestimate the power of pooling knowledge.
:P
i'd be keen to see a dyno graph of your auto R32 making 160rwkw :)
i made 132rwkw with the auto rb20 having 3"dump/front/cat-back (stock cat), FMIC, 12psi, chipped ecu (AFRs were 10-10.5 though), rb26 cams, and panel filter with CAI
i thought the auto robbed some power out of it personally but you seemed to do nicely!
EDIT: actually i just noticed in another thread that you have the MV automatics shift kit in your auto box as well... was this put in after the 140rwkw run?
would this have contributed to the dyno figure or is it purely gear changes as the name would imply?
did anyone else notice that Paul R33's car is an AUTO?
doesn't this make a difference to power at the wheels?
don't they have different ratio's?
and how do they keep it in the gear that is 1:1 ratio as the auto kicks back if floored.
just a thought.
its not auto, where did you get that idea from? i need to find a workshop who do me a dyno run with the exhaust disconnected to see what power i make with the exhaust off
ummm...
from the post that you put up..
http://www.skylinesaustralia.com/fo...achmentid=26012
Stock turbo
Stock cooler
10 psi
Cat back zorst
Pod
Auto Tranny
where it says "I'VE GOT"
I assumed that meant that YOU'VE GOT since you are the one posting.
I made 209rwkw, and 420nm Torque NOT in shootout mode, done on 2 different dynos.
Is that good?
PFC
FMIC
Pod filter & Partition
12psi
Full Custom Exhaust and Hiflo Cat
Standard Turbo, Standard Injectors, and Standard Fuel pump.
Same mods without the powerFC made 141rwkw at 10psi
I don't give too much of a shit about top power. I want torque..
    • att.4QNbuJlz_gNZPFBGFqeEvxSUHXkGt7z40V59MrtXTPg.mp4
    • Plan on the day will be to park trackside. Depending on space availability we will try put a small shade tent and a few of the cars on top of the hill inside turn 3, this is an easy to get to parking area with views of Turn 2, Turn 3, Turn 4 and Turn 5 and limited other pieces of the view around the track. IMPORTANT NOTE! One consideration from previous years is from memory the trackside parking sells out before the admission tickets, for that reason I encourage anyone planning on coming to buy tickets for parking now via the official website; https://www.worldtimeattack.com/ The type of parking you are looking for is 2 Day Park & View (Access Around Venue) Vehicle Pass Only Please note this does not include admission to the event itself, remember to grab that also, and kids under 12 get in for free!
    • This is going to be a mid week evening cruise. Come along and join us for a drive out to Palm Beach. This is a change of event plans after talking to some of the older members of the club. SAU NSW is planning on hitting Old Pac again shortly, stay tuned for details. When: Thursday 26th of June Time: 7:30pm meet/8:00pm departure/10:00pm finish Meet: Spit West Car Park / Spit Rd Mosman NSW 2088 Destination: Palm Beach Public Parking / 16 Ocean Rd Palm Beach NSW 2108 Up to date information as always can be found on the events page of our website, the link for this event is https://www.saunsw.com.au/events/palm-beach-cruise There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAUNSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • Good time for a carbon roof
    • Not in any way aroused by any of those, except maybe the big AMGs. And that would break my never a Euro, ever, rule.
