I had platnum's in the car, when i ran 14psi through an rb25 turbo i found that it would blow out the spark. So i got some copper plugs at 0.8mm gap and it works a charm. You could spend big bickies on the iridiums and platnums but the coppers work well for me and cost be $17 for all 6.
i use the spitfire Vs' in both my cars, one turbo one N/A, they have platinum tips with a V pattern. in the rb20 i run 10psi on a standard turbo but soon i'll see how they go with a rb25 turbo at 14psi.... about $13 each as well.
Very interesting sky30. Im using the bcpr6es at the moment, with a 0.6 gap and its still missfiring badly (19-20psi, 300rwhp). Going to check the coil packs but wouldnt mind trying the bcp6es if that fixed the problem in yours. Would you mind passing on any more details on your setup ?
Thanks
So what does the 'S" designate? I had the BCPR6ES and also had misfire problems and then they were changed for BCP6E which stopped the misfire.
I asked about the R which I was told was a resistor to stop interference from stereos or something but dont know what the S stands for. I double checked and they are definatelty BCP6E.
DCIEVE:- I would try the BCP6ES non resistor plugs before anything else, i gap mine at .7mm for 20 PSI in my R32 making 306rwKW, no misfiring.
BCP6ES are just standard RB30/VL ones.. they are like $10 a packet.. lol
Don't you need the resistor type as to not interefere with the other engine electrics? that is what I was told anyhow. Not sure if its correct or not?
I use BCPR6ES-8 for normal use, maybe BCPR7ES-8 for sustained high speed or track use;
B: Indicates 14mm thread diameter in the cylinder head.
C: Hex size 5/8"
P: Projected insulator type
R: Resistor type
1-9: Indicates temperature (1 Hottest - 9 coldest)
E: Indicates 19mm thread reach (approx 3/4")
S: Standard (copper) 2.6mmø center electrode
-8: Gap 0.8mm (0.032")
If you can't get -8 then you will have to adjust the gap to 0.8 mm before you fit the plugs.;)
Sk what is your opinion on the non resistor typre plugs preventing missfire?
SKY30, what motor is in your 32?
Going to swap the plugs (again) for the non resistor type tomorrow.  Will let ya's know if works
The ceramic resister (usually ~5K ohms) is there to suppress the electronic interference from the ignition during sparking. Crackle n the stereo is the most obvious result, although I have seen the ECU and instruments interfered with by the noise generated from using non resistor plugs in a car designed for resistor plugs.
From the NGK tech journal
"NGK strongly recommends using resistor spark plugs in any vehicle that uses on-board computer systems to monitor or control engine performance. This is because resistor spark plugs reduce electromagnetic interference with on-board electronics.
They are also recommended on any vehicle that has other on-board electronic systems such as engine-management computers, two-way radios, GPS systems, depth finders or whenever recommended by the manufacturer.
In fact, using a non-resistor plug in certain applications can actually cause the engine to suffer undesirable side effects such as an erratic idle, high-rpm misfire, engine run-on, power drop off at certain rpm levels and abnormal combustion."
The botttom line, I would never use non resistor spark plugs in my Skyline:cheers:
  • 1 month later...
ok i dont know what to go on but what would be the best for my rb20det, it will be running 19psi, has high flowed turbs, hks front mount, 3.5inch exhaust, cai, bosch 040, gtr injectors, splitfire coilpacks, tomei poncams.
i want to know what are the best ones not value for money
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
