Have been offline for a bit, sorry fellas
Could i please have my name changed to Esc
If that is taken could i please have Select
Please can i change my username to GTRR
Thanks
Please change my user name to SPOOLZ
Doesn't seem to be taken
Thanks
Can my user name be changed to FeeninPerformance, if possible?
All done!
Please change my name for 7 days to Mr SHiRTman
Please change my username to Guilt T-ripper for 7 days too =)
You might need to remind me to change them back!! :(
Hi,
Could i please get my name changed to sunnycoast.
Thank you
Taken mate, sorry!
Edit: actually on closer inspection, it's taken by you, lol. If you're happy for me to do so I can rename the existing 'sunnycoast' account to 'sunnycoast-old' then go ahead with your name change
Taken mate, sorry!
Thats fine mate.
No probs at all.
Thanks heaps.
I've given it some thought, TR11KY my current username is what im known as in my other car, My skyline and hence what i'll be known as here is STYLN, so could i graciously ask admin to change my username to "STYLN" please.
Cheers :(
Cheers :wub:
yes please.
DiRTgarage is the correct mix of capitals and lower case.
can you change my username to sanluu
thank
request a change of username to PhilKenSebben
All done guys :blink:
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
