Hi all,
Could i please change my username from STARION4ME to BarbsGTR
I joined up a very long time ago whereby i had a nissan powered Starion. Ive since bought the car of my desires
With thanks
Jason
Hi all,
With thanks
Jason
Can i please have my name changed to:
WGNPWR
thanks :cool:
Both done :D
Howdy, can i get my username changed to Cake, as I use that on other forums also I wear pants (mostly) nowadays
Taken, sorry :down:
Can I have mine changed to boostn0199
can i please get mine changed to Mohsen??
cheers!
Hello, can I get my username changed to Telcontar
Long-standing username of mine when I used to play WoW and from before that, during high-school.
All done!
Can I get mine changed to Jay34?
Thanks :P
Already taken, sorry :huh:
thanks revhead..
can you please change it to Mohsen again?
another mod changed it for the lulz
Hahaha awesome :O
Changed again!
Already taken, sorry :laugh:
Hahaha awesome :)
Changed again!
Really? I checked the members list and it says there's no results for Jay34....?
there's a Jayr34 and a Jay.r34.
hmmmmm, if it's deff not available then I'll settle for Jay11
Thanks.
Edited by jaylon
Thanks.
Yeah someone has used it for their logon name, but not their display name, it won't show up in the search that way unfortunately. Ah well :rofl:
Changed to Jay11 instead!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
