Hi all,
Could i please change my username from STARION4ME to BarbsGTR
I joined up a very long time ago whereby i had a nissan powered Starion. Ive since bought the car of my desires
With thanks
Jason
Hi all,
With thanks
Jason
Can i please have my name changed to:
WGNPWR
thanks :cool:
Both done :D
Howdy, can i get my username changed to Cake, as I use that on other forums also I wear pants (mostly) nowadays
Taken, sorry :down:
Can I have mine changed to boostn0199
can i please get mine changed to Mohsen??
cheers!
Hello, can I get my username changed to Telcontar
Long-standing username of mine when I used to play WoW and from before that, during high-school.
All done!
Can I get mine changed to Jay34?
Thanks :P
Already taken, sorry :huh:
thanks revhead..
can you please change it to Mohsen again?
another mod changed it for the lulz
Hahaha awesome :O
Changed again!
Already taken, sorry :laugh:
Hahaha awesome :)
Changed again!
Really? I checked the members list and it says there's no results for Jay34....?
there's a Jayr34 and a Jay.r34.
hmmmmm, if it's deff not available then I'll settle for Jay11
Thanks.
Edited by jaylon
Thanks.
Yeah someone has used it for their logon name, but not their display name, it won't show up in the search that way unfortunately. Ah well :rofl:
Changed to Jay11 instead!
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
